Spc initial settings
Melton87
Hi,
I tried searching but somehow nothing popped up for spc, or alignment, which I find hard to believe.
Looking for help on initial settings for my spc UCA's. Getting dobinsons ims 3"front, 2"rear. Tires size 265/70r17 with 1.5" spider Trax spacers.
Also, what are the target numbers I should give to the alignment shop?
Thank you!
Hi,
Thank you!
Follow the instructions and set them at 0. That setting gives you +2 caster right out of the box and the alignment shop can adjust from there.
265/70/17 is gunna be small with that lift. You will clear just fine running 285/70/17. I run those with Tacoma shocks and FJ rear springs right now. With the SPC UCAs, there's no rubbing.
Ya, i figured they'd be small. Will eventually go bigger and sell these. I just bought brand new bfg all-terrains last winter, before I had ever thought of throwing a lift on here...
