Originally Posted by zeekevin
Looks great and I’m sure in functions even better... did you change out all the soft lines to ss brake lines. Also did you flush out the brake fluid system? How hard was it to get the system to completely bleed all the air out?
Yes, the stainless brake lines were included with the kit. Flushing and bleeding the kit was not difficult. Used both a pressure and vacuum system. Six 12 ounce bottles of OEM fluid did the trick. I read somewhere that the master cylinder for the 4th gen has a defective seal. Can only use OEM brake fluid apparently.
Originally Posted by AuSeeker
Very Nice!
Just a question and a confirmation, does the parking brake function correctly?
I believe you stated in an answer to my question in another thread that one would have to have 18" wheels for these to be installed, correct?
Yes, the rear hats were designed specifically to work with the 4th gen parking brake assembly. Rotora also makes hats to work with the 5th gen parking brake system which I believe is a bit different.
Correct. 18” wheels are required to run 14” rotors.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
