Old 04-07-2021, 10:17 AM #1
PJP71 PJP71 is offline
PJP71 is on a distinguished road
3rd gen Tacoma TRD Off Road suspension swap - What rear springs should I get?
2007 4Runner Sport 4WD V8
I'll be ripping out the XREAS and installing some front springs/shocks from a
2019 Tacoma TRD Off Road with less than 5k miles on them. I'll also be adding 3/8" top hat spacers from Wheelers Off Road.
From what I have read, the Tacoma springs/shocks give around 2.0-2.25 inches lift and the top hat spacers around .5" lift for a total of approximately 2.5-2.75 inches.
I'd like to level it out but don't mind a tiny bit of rake. No heavy bumpers and don't usually carry heavy loads. Daily driver, occasional light offroading.
I saw some used Icon 2 inch rear springs (part# 158506) locally but they have been replaced by a new part number and I can't find much info on them. I wanted to do a full dobinsons set up, but its not in the budget right now and came across the tacoma parts cheap.
Does anyone have any recommendations or suggestions for the rear springs???
PJP71 is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 03:56 PM #2
I have seen where others have done this swap (without the top hat spacers) have used the Bilstein B12 1.8" and are sitting pretty much level. So thinking I may need a spring that give right at 2 inches of lift.
Does anyone know of such a spring? Any input is welcome.
Old 04-07-2021, 05:29 PM #3
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Icon makes a 2" rear spring IIRC
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 06:00 PM #4
Thanks for the reply. Yes, I came across some used Icon springs I'm considering. I believe Toytec makes some as well. I just want to make sure I don't have a lot of rake....or too high in front.
Old 04-07-2021, 06:07 PM #5
Placemotorsports Placemotorsports is offline
Placemotorsports is on a distinguished road
I did this swap, no front added spacer and put a 1.5" spacer in the rear of my factory springs and there is still rake. So much that I'm going to put a 1" spacer in the front to try and level it out
Sent from my SM-G991U using Tapatalk
Placemotorsports is offline   Reply With QuoteReply With Quote
hat , rear , road , tacoma , top
6112/5160 - Do I need rear springs/spacers, or can I reuse factory rear springs? darksparkz 5th gen T4Rs 8 09-29-2020 12:18 PM
Sold: FS - Dobinson C59-675V Rear Springs - 3 inch lift springs - Denver - $175 Spudgey For Sale: Suspension/Wheels/Tires 1 07-21-2020 06:12 PM
OME 906 Rear 2" lift springs $140 (Colorado Springs) 99 sr5 highlander For Sale: Suspension/Wheels/Tires 2 06-28-2015 11:13 PM
Need new rear springs that work with Bilstein HD's. Stock springs isn't doing it sugjavier 3rd gen T4Rs 5 08-16-2014 06:15 PM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
