Old 08-19-2023, 04:22 PM #16
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
Coverlay Install Return to Directory
Installed this a few weeks ago. My dash has been cracked for years but this summer my car has been parked in direct sunlight and its gotten much worse. I picked up a coverlay for ~ $120 and installed it. It was not a perfect fit. Corners of dash were swollen on both sides and it did not fit over the edge by front defroster too well. I left it in the car for a few days to heat up and siliconed it in place. I opted not to put the airbag cover on as it wasn't necessary.
Overall fit is 8/10. Install was super easy and I assume the fit is off due to the age of my dash and swelling over years.
CBR's Build Thread CBR's Build Thread
I also noticed my whole build thread is one long page... is it showing up like that for anyone else? not sure how to fix it.
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread: CBR's Build Thread
My Write-ups: How to Manually Release Rear Hatch with Pictures
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 09:39 AM #17
Real Name: Chris
Real Name: Chris
I have been hearing a loud clunk the past few days driving and more specifically turning. It has been intermittent but I knew something was not right. Finally got it located to the Driver side rear with my head out the window driving and found this....
CBR's Build Thread
Going to be interesting replacing my Rear links while at school with only the car jack included with the car. I was going to replace these a few years ago when I replaced the front but my mechanic said it was not necessary if bushings were still good.
Bought TRQ PSA55972
Old 11-12-2023, 11:32 PM #18
Real Name: Chris
Real Name: Chris
OEM Idler Pullies just crapped out on me. They started to make a loud noise whenever the engine is running and its bothering the hell out of me. I am not sure which one it is, but I might as well take this as an opportunity to replace all of them If I am in there. I see it is much cheaper to swap the bearings themselves vs buying a whole new pully but I do not have access to a press.
Other than that seems pretty straight foward
Old 12-30-2023, 03:39 PM #19
TN4Runnin's Avatar
TN4Runnin TN4Runnin is offline
TN4Runnin is on a distinguished road
TN4Runnin's Avatar
Originally Posted by chrisbagnell View Post
I used a hanger with a coating on it, for two reasons. It was the only one with the same thickness as OEM rod and also prevents rust/corrosion... Took a little bit of tinkering to get the right bends but this has been working for months without failure. I hope these pictures help with your build!
This helped a lot! Late response but was able to come up with something similar. Really appreciate it!
TN4Runnin is offline   Reply With QuoteReply With Quote
axle’s , gas , skid , suspension , tank
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
