Old 07-18-2021, 10:49 PM #1
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
TPMS and new wheels
I ended up with a set of off road wheels for my 04 sport that I got off here!
What should I do for sensors? Im gonna go OEM but do I match the part number from the 18 or 04? Does it matter?
My old ones are still on the old wheels but one is a rubber valve stem but I think there is a sensor in there because the light was off when I had those wheels the light was off. another one of them was really hard to fill with air and was shorter then the rest. Id like to just get a new set
Monty87ls is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 04:57 AM #2
Flesh Eater Flesh Eater is offline
Flesh Eater will become famous soon enough
I grabbed new Denso’s off Rock Auto.
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 09:26 AM #3
Thats other option, I currently have 1 of the Toyota TPMS on the spare and it will not be changed. Do I get them for a 2018 or 2004? or aftermarket or they all the same when aftermarket. If I go the aftermarket route I mean
Old 07-19-2021, 11:04 AM #4
montijo505's Avatar
montijo505's Avatar
Regular valve stems and bypass the light. I’m doing this when I get new tires.
Old 07-19-2021, 05:19 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
While the 2018 might be compatible with your 2004 T4R, I would get them for a 2004 T4R, otherwise you risk them not syncing up with the TPMS on your 2004.
Either way whoever mounts your tires will need to program/activate them to your T4R.
2004 Limited V8
Old 07-21-2021, 04:15 PM #6
GeoFlory's Avatar
GeoFlory GeoFlory is offline
Real Name: George
GeoFlory is on a distinguished road
GeoFlory's Avatar
Real Name: George
This brings up a question. Everybody with a 4th gen has aging TPMS sensors unless they already changed them or threw them away. I have the newest of the 4th Gens with an '09. I am about to buy new tires. My 12-yr-old TPMS sensors are still working; should I replace them with Denso's which should be identical to Toyota (@$/2), or should I wait for them to fail and replace them then. They are supposed to last an average of 10 years. I am not going to deactivate the system; I tend to be a bit negligent about regular checking.
1998 4Runner Ltd, V6, 4WD -- Traded for '07
2007 4Runner Sport Ed, V8, 4WD
2009 4Runner SR5, V6, 4WD
GeoFlory is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 12:06 AM #7
Hmm well I think I'm just gonna go the rubber valve route to cut costs and get get the light off.
If I was you I would consider just replacing them since your gonna get new wheels. Might be worth the cost to do it now and not end up paying twice to have the wheel taken apart again.
Old 07-23-2021, 12:26 PM #8
venomj venomj is offline
venomj is on a distinguished road
I did the same thing.
venomj is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 01:55 PM #9
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
FWIW My 06 is still running with original sensors. I'll probably replace them next tire change unless I have issues before. I like using them W/ the scanguage to air down/up as needed for the trial. (also nice to be able to see if that idiot light is on just cause it's a cold morning and the spare has not warmed up, or if there is a real problem.)
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 06:05 PM #10
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
+1 on this. I was looking at 5 tires at $65 per sensor plus a $99 programming fee from my local tire store. I'd rather have $400 for other mods.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 06:55 AM #11
GeoFlory's Avatar
Real Name: George
GeoFlory's Avatar
Real Name: George
Well, I asked Sam's, and they said they did not sell TPMS sensors, but would install them for free if I provided them. I bought five Denso PN 550-0103 TPMS sensors from Amazon @ $33.13 ea. I bought four Cooper 265/65R17 AT3 4S tires from Sam's; Sam's is installing the tires and sensors Monday (2021-08-16) on my '09 SR5.
Meanwhile, my '07 Sport Edition proved the value of the TPMS sensors. I got a tire-pressure-warning light a couple weeks ago; one of my months-old tires was low. I aired it up and a week later the light was on again; this happened twice more with several days interval. The TPMS was warning me each time. I said to myself that this is getting serious, but I had never had a flat on brand-new tires before. Knowing that tire-repair places cannot find leaks in tires, I took the tire off to find the leak myself; it was easy; there was a drywall screw sticking thru the thickest part of the tread. I took it to the tire-repair place, and they told me to leave the vehicle and they would get to it in turn. I went to the auto-parts store and bought a repair kit, went home, and in five minutes, repaired it myself.
The bottom line is that I have had several flats on the expressway (very unpleasant), destroying the tire, and in one case, destroying the wheel. Tire-pressure sensors are great; I would never be without them again.
Old 08-13-2021, 12:00 PM #12
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I was in a similar situation when I switched to newer wheels from 2020 Tacoma. My stock wheels and tires had some life left on them so I didn’t want to touch the existing sensors.
The new wheels I bought had regular valve stems and no sensors. I drove around for a while but hated having the light on. I ended buying a used set from a friend who took them off his 2015.
The challenge at this point was not getting them installed but getting them programmed. Most places I called quoted me outrageous prices to program them. In the end a local shop charged me $50 to install the sensors onto my existing wheels. I have ended borrowing a Autel TPMS tool to program them myself. It was super easy. I can’t believe how complicated shops make it sound.
Personally I would try to keep them if you could.
zguy1 is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 04:11 PM #13
I ended up scraping them, I check my tires constantly anyway old habit of trying to being on tip of my auto maintenance.
I went with cooper also just 70 instead of 65s, one thing I will say is the tries report you did I'm guessing is tire plug? Keep in mind they are only supposed to be temporary fixes until a proper patch plug can be used. Sams does the repairs using those.
A lot of shops will throw a plug in it in the hopes it leaks again and then you comes back and they sell you a tire.
Old 08-14-2021, 06:45 AM #14
GeoFlory's Avatar
Real Name: George
GeoFlory's Avatar
Real Name: George
I was unaware plugs are supposed to be temporary. I have seen shops use them and I have too. For me, the plugs have always lasted the life of the tire.
I looked it up on the Internet; they give several reasons which I am not concerned with:
Unless the object is still in the tire you can't tell exactly where the hole is. I can see the validity of this for an unknown leak, but my object, a 1.25" drywall screw, was in the tire; I inserted the plug directly thru the same hole--no problem.
The shop can inspect the inside of the tire for additional damage. Again I can see the validity of this for an unknown leak; it could have been caused by hitting a pothole at high speed and virtually destroyed the tire, but I am confident that the drywall screw wouldn't cause additional damage inside the tire--no problem.
The patch could leak moisture into the steel belts corroding and delaminating them. This screw went thru the thickest part of the tread; the plug is super tight and sealed in the closed up rubber; I am confident that no moisture is ever going to get thru it--again no problem.
The reasons they give for it being a temporary fix have convinced me that I can regard it as a permanent patch -- it sure isn't going to fall out.
Old 08-14-2021, 12:59 PM #15
Hey I've done it also but for me after seeing first hand what happens to the tires that do fail with them in or just constant leaking after id rather just do it right the first time. A lot of people ride the low for awhile and tear up the sidewalls in the inside and most discount places don't care or the tech doesnt care or is inexperienced and just plugs it and lets it go.
Another thing that stops me now from doing it is warranty. Plugs will void the warranty most of the time if noticed anyway and since I get my tires at sams and they are stickers for everything and its free repair also.
That being said have I done it? yes... Did I at one point within the span of 2 days get 7 nails in one tires thanks to construction around the corner from me... Yes. Did I plug all of them... Yes.
I mean I also replaced all 4 tires 4 days later but still.
My record when i was working was 4 in one hole and it held for 2 days! haha
Thats what she said...
light , rubber , set , valve , wheels
FS: 5th Gen SR5 wheels w/TPMS & tires $700 NJ sarcoid For Sale: T4R Items 2 10-15-2019 08:22 AM
Swapping SE wheels for LE wheels - TPMS question T4R # 5 4th Gen T4Rs 14 06-25-2015 09:22 PM
tpms to TE wheels oljedi11950 4th Gen T4Rs 0 12-05-2013 03:31 PM
tpms to TE wheels oljedi11950 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-29-2012 07:48 PM
Wheels without TPMS? traffic626 5th gen T4Rs 3 05-04-2011 12:39 PM
