Closed Thread
Old 08-22-2021, 03:23 PM #1
Lewis&Clark Lewis&Clark is offline
Real Name: Dan
Lewis&Clark is on a distinguished road
Real Name: Dan
Question Hewitt Gen-II SAIS Bypass Kits
If one installs this kit, does the bypass degrade performance or reliability at all? My read is there is nothing actually wrong with the SAIS, just an error in the ECM on cold starts that is bypassed by this kit.
Is that accurate?
If I install, will I be able to pass a California smog test?
2008 4Runner V8 Limited ("Lewis"), all factory options.
Old 08-22-2021, 04:02 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Is that accurate?
Someone else can chime in with more knowledge, but the SAIS failure doesn't just cause an error code, it puts the engine in limp mode making it pretty much undriveable. So installing the kit can only increase reliability.
Inv4drZm is offline
Old 08-22-2021, 06:47 PM #3
Real Name: Dan
Real Name: Dan
Yes of course. I should have noted that. It’s in limp mode with the codes, but I’ve already replaced the SAIS pump and filter. Can’t figure out why it’s still pushing the code and putting it in limp mode. Some reading on the forum led me to believe this is a common glitch in the ECM and this bypass kit can resolve it.
The car is worthless if it isn’t drivable. So wondering if this kit will make it usable again — and by that I mean I can drive it just fine AND be able to pass a California smog check.
Old 08-22-2021, 09:00 PM #4
Real Name: Skip
Real Name: Skip
You haven't stated which code you're having, there numerous codes related to the SAIS?
2004 Limited V8
Old 08-22-2021, 11:32 PM #5
Real Name: Dan
Real Name: Dan
Most recently (last Tuesday), my reader was showing P1442, P1444, and P2441. Took it to the mechanic for repairs. I didn’t look at the code when the problem returned the day after getting the repairs done; I just limped it back to the shop and left it with them. That was Saturday. They haven’t called back yet with a code or diagnosis.
Old 08-22-2021, 11:42 PM #6
Real Name: Skip
Real Name: Skip
If you haven't seen this web page, maybe it will help and also answer some of the questions you have.
Hewitt-Tech | SAIS Failure & Bypass Codes
2004 Limited V8
Old 09-06-2021, 08:00 PM #7
Real Name: Dan
Real Name: Dan
Ended up not needing the bypass kit at all. Originally replaced the pump and filter, and when the problem persisted, the mechanic found some tubes that were worn out and hadn't secured very well to the new pump after they put it in. They replaced them at their cost, and the problem vanished. That was almost 1500 miles ago. Knock on wood, the problem seems to be gone.
Closed Thread
bypass , cold , hewitt , kit , sais
Resale Value Concern with SAIS bypass BigMike18 4th Gen T4Rs 14 01-06-2023 07:20 PM
Hewitt-Tech Plug & Play SAIS Bypass Kit - $95 drewj For Sale: T4R Items 0 03-12-2021 11:42 AM
SAIS bypass kit not working? darkgun82 4th Gen T4Rs 8 08-24-2020 03:14 PM
FS: SAIS Plug-and-Play Bypass Kit + Pump Replacement Pack - $350 - Charlotte, NC bigmike91 For Sale: T4R Items 6 09-05-2017 11:36 AM
ByPass Kits Fatty Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-13-2004 08:50 PM
