Originally Posted by Too Stroked
While I absolutely agree that rebuilding calipers with OEM parts is a great way to go - if you know what you're doing - I simply cannot fathom your success criteria. If NASA uses criteria like that on the upcoming manned Mars mission, it's not going to make it off the launch pad.
LOL, a comparison to NASA mission to Mars? I see your point, but curious as to what kind of criteria you like to see. My criteria is:
-It stops when I push the pedal
-No fluid leaks
-No frozen pistons (but the design makes that inevitable at some point with out regular dust seal replacement)
-regular, even pad wear
Not sure what else, basically working brakes. What else is needed?? In this case, brake calipers are very simple. Only general mechanical/car knowledge is required.
