Old 12-08-2021, 01:59 PM #16
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
My shifter is a tad sticky moving from 3rd to 2nd. It takes a bit of finesse to ease the shifter over.
Is this a sign of the linkage bushing going? Or something to do with the guide pins?
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:07 PM #17
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I suppose I'll do this in the interest of preventive maintenance (my truck is at 221K miles) but it grinds my gears (ha!) to spend $25 on a plastic washer.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 03:16 PM #18
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
doubtful, but could give you some insight as to whats going on when you take it apart to replace the bushing. I didn't bother figuring out exactly what gives the springiness to the shifter and how the whole mechanism works when it was apart since I was more curious to fix the shifting issue.
aemravan is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 05:07 PM #19
Bluesky 07's Avatar
Bluesky 07's Avatar
The listing pic shows 2 pieces in the bag - do they fit together to create the one bushing or do you get two bushings?
Old 12-08-2021, 06:37 PM #20
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The second piece is a "Installation Driver", but they say you can install the bushing without it or you can use it if you need too, here's a link to a YouTube video from the manufacturer's website the link I'm posting is straight to YouTube, the video says it's for a "Toyota Matrix" but the bushing installs the same on our 4Runners, you just basically just push the bushing into the cable eyelet, the guy actually is talking but I couldn't hear him on my laptop until I used headphones.
The easiest way to fix your Toyota Matrix shift cable! Kit includes replacement bushing. - YouTube
2004 Limited V8
Old 12-11-2021, 04:51 PM #21
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I just received and installed the bushing. It was very easy. The old bushing was still compliant, I will keep it just in case.
Alternate method (no need to remove whole assembly):
1) remove the shifter surround by lifting straight up
2) unscrew the shift knob
3) move the shifter to a mid point like N
4) with a small flat screwdriver, gently release the lock tabs at all 4 corners
5) lift and remove shifter Bezel.
6) move shifter to 2nd gear position
7) look at the rear most end of shifter assembly, and you can see the shifter cable and bushing
8) follow the shifter cable back 3” and see a flat spring clip holding the cable in the mount
9) with pliers, pull up the clip and remove. Push cable backward and lift from mount
10) slide shifter bushing/cable off the selector post, lift the cable to access the bushing.
11) remove bushing, install new bushing, lubricate, re-install on selector
12) reverse process to finish.
13) note: Be careful not to lose the shift lock release button when installing the bezel
=> take pics along the way to help with reassembly
Time involved, 20 minutes including dropping and retreiving the shift lock release button from under the shifter. LOL
A friendly shifter linkage bushing reminder-2c5d9c34-5284-49ce-bd45-1220f1c26955-jpeg  A friendly shifter linkage bushing reminder-9303c4ed-858d-4057-a319-a79d2de18def-jpeg  A friendly shifter linkage bushing reminder-098b6027-7b10-484e-8bda-8636d67ae5e4-jpeg  A friendly shifter linkage bushing reminder-8afa232b-97e3-49ca-a78d-6eaa71f90e02-jpeg  A friendly shifter linkage bushing reminder-d67dbbd9-720e-4e96-b566-126b12dcf6c5-jpeg  A friendly shifter linkage bushing reminder-1370e27a-1951-4ba5-a664-4282f25eddba-jpeg  A friendly shifter linkage bushing reminder-34dfdcef-b96e-4ec5-b672-9f549839432d-jpeg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 12-11-2021, 05:13 PM #22
Drcoffee's Avatar
Drcoffee's Avatar
More pics. Flat spring clip at yellow arrows
A friendly shifter linkage bushing reminder-2fe4be03-b677-45f0-abaa-ef2fac1881e5-jpeg  A friendly shifter linkage bushing reminder-e4e0c997-9edf-451a-9ff2-d20912f6c1a4-jpeg  A friendly shifter linkage bushing reminder-7782f60f-ba6c-496a-a2b6-504fd18d0386-jpeg
Old 12-13-2021, 01:49 PM #23
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
You posted instructions about 2 hours after I finished xD Should have procrastinated.
Side note, I could not get the flat piece out to save my life. Not having any instructions to show me otherwise I ended up disassembling more of the shifter.
These instructions are way better lol.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 12-13-2021, 02:26 PM #24
Drcoffee's Avatar
Drcoffee's Avatar
Its a tight fit. With pliers, you will need to pull straight up and rock it side to side to get it out. Or find a way to pry it up. The tap with a hammer to reinstall it.
Old 01-02-2022, 08:27 AM #25
rancho66 rancho66 is offline
rancho66 is on a distinguished road
SHIFT LEVER & RETAINER. Tacoma | Toyota
3357222010 - Grommet (for floor shift control shaft). Transmission, driveline - Genuine Toyota Part
Probably the Toyota OEM part(s) for this repair. Check with your dealer to make sure.
rancho66 is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 10:17 AM #26
Real Name: Skip
Real Name: Skip
Originally Posted by rancho66 View Post
If you checked for "what this fits" you will see that's for 3rd Gen 4Runners not 4th Gens,
2004 Limited V8
Old 01-02-2022, 11:28 AM #27
Bluesky 07's Avatar
Bluesky 07's Avatar
Appears from this diagram that the 4th Gen OEM grommet is part of the $200+ cable assembly.
Old 01-02-2022, 12:17 PM #28
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
I've been wanting to replace this bushing for a while since my transmission sometimes sticks going into Drive. I found the same bushing kit that others here posted links to while looking on Amazon for something else.
Amazon.com: Bushing Fix BP1Kit - Transmission Shift Cable Bushing Repair Kit : Automotive
Hunter61 is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 12:58 PM #29
Drcoffee's Avatar
Drcoffee's Avatar
I bought mine from ebay after offering $20. Probably still $15 over priced but its a one time purchase
Seller. Bushingfix
A friendly shifter linkage bushing reminder-e3063f3e-5fbf-4fbd-87df-f6f4a6013ec1-jpg
Old 01-02-2022, 01:43 PM #30
Real Name: Steven
Real Name: Steven
Seller. Bushingfix
I got mine for free using the Amazon gift card I got for Christmas.
bench , broke , bushing , linkage , shifter
another friendly reminder to get a dash cam s20004runner 3rd gen T4Rs 31 05-19-2018 04:35 PM
4x4 Adventures Friendly Reminder ben550 Off-Roading 3 07-03-2015 06:21 PM
Friendly reminder- Change you cabin filter (pic) lunchindabox 4th Gen T4Rs 20 07-04-2013 05:12 PM
A friendly reminder to not neglect your fuel filter notrayray 3rd gen T4Rs 53 08-27-2011 03:47 PM
friendly reminder about spare Savage Classic T4Rs 4 01-24-2010 08:58 PM
