Originally Posted by Bluesky 07
Were you on a road? DAC is for off-road use & only works in 4LO so that explains why nothing happened. Can’t help you with the beeping, but I’d start with cycling through all the 4WD modes.
That was my first instinct, once I realized the beeping wasn't going to stop I switched to 4Hi and pressed the DAC button but it didn't do anything. I have also disconnected the battery and left it that way for about 20 minutes to allow the ECU to reset. No improvement. I'll try it in 4LO next, luckily the roads in this neighborhood are caliche.
