Old 07-25-2022, 03:30 PM #16
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
When I had this issue it was that relay sticking in the on position. There's multiple relays in that box that are the same model. Try switching the A/C one with one rarely used and see if that helps.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-25-2022, 05:21 PM #17
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
My '06 did this the other day when I punched it to get on the highway. All the same symptoms. Shut the a/c off and back on and it was fine. Been ok since.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, B12 coils, Borla duals, Fuel Catalyst rims, Nitto At3 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, Enkei XSP wheels, Michelin AT2 275/55/20, TRD Exhaust, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 07-26-2022, 06:15 PM #18
4rs 4rs is offline
4rs is on a distinguished road
4rs 4rs is offline
Mine used to do it and I would shut it off then turn back on and it would correct it. But now it won’t correct it turning it back on
4rs is offline   Reply With QuoteReply With Quote
Old 07-26-2022, 06:16 PM #19
4rs 4rs is offline
4rs 4rs is offline
I tried switching relays. No success.
Old 07-26-2022, 06:18 PM #20
4rs 4rs is offline
4rs 4rs is offline
Originally Posted by importman View Post
One thing that can cause this is the revolution sensor in the compressor. If it doesn't send a signal saying that the compressor is turning the computer thinks it's locked up. In order to prevent the belt from being burned off it will turn off the compressor and signal the lamp to blink. I don't know if that's what you've got but it is a possibility.
This is great info. Can I replace the sensor without replacing the compressor? Can I do it myself? Possible to test it?
Old 07-27-2022, 03:14 PM #21
MikeinNH67's Avatar
MikeinNH67's Avatar
Bummer. You may need to bring it to someone who can diagnose. Maybe you have some blockage and it gets over pressurized but at this point there's no way to narrow it down without the proper tools.
Mike
03 4runner Limited
Old 07-27-2022, 09:09 PM #22
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So I tried that on mine- bringing it to an AC shop. because it was blinking and they couldnt get the system operating, they couldnt use their computer diagnostics. So then they were advising the replace the HVAC control panel as the next logical step. After my research, the HVAC control module made the best sense next and ended up being my issue.
I think the OP is left with you can bring it to a Toyota dealer for a high priced estimate, or you can start replacing the cheapest and easiest next things.
If you replaced your compressor, the revolution sensor shouldnt be an issue
Old 07-27-2022, 10:53 PM #23
4rs 4rs is offline
4rs 4rs is offline
I had this problem intermittent for a few years. I replaced the hvac controls last year with a used one I sourced. The issue still persisted. You think it really could be the hvac control? I don’t want to start dumping money replacing piece by piece though. I never replaced the compressor.
Old 07-28-2022, 02:20 PM #24
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
To be honest I'm not totally sure. On some older model Toyota products I can remember replacing just the sensor but I believe on newer models, you have to replace the compressor. But don't hold me to it. You might want to take a look at it and make sure the connector going to it is plugged in and secure. I think it will be basically screwed into the side of the compressor with a 1 or 2 wire connector going to it. It will be separate from the connector for the clutch. Good luck!
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 11:56 PM #25
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
Oddly it works intermittent. Like this morning. Then I shut off and then back on. Then it doesn’t work. Now I just checked and did the diagnostic again, which showed the 00 code. But it’s working again. I’m wondering if I need the updated relay. The grey one. Which I have in order.
I just went through two AC repair jobs on my truck within 18 months. This most recent time, I was having intermittent problems with the blinking AC light and it ended up being that I needed a new Compressor. The first time, a shop installed a full AC kit made by Import Direct. Well that import direct Compressor failed 18 months later. We should have put OEM Denso parts in the first time, lesson learned. Also, I learned from a shop that does lots of Toyota trucks, skip replacing the expansion valve because they are pretty bullet proof from the factory and avoid having to pay for the dash to be removed.
My suggestion, find a shop that is reputable and honest, go get them to diagnose the problem and you very well may save money in the long run instead of replacing random parts. Unfortunately, AC systems are pretty complex. It isn’t impossible to do DIY, but it may be a long frustrating road. I started down the DIY route like usual, but IMO your time may be better off letting this get diagnosed by a pro. Good luck with whatever you choose!
TejasRunner01 is offline   Reply With QuoteReply With Quote
a/c , blinking , faulty , light , packs
4lo Blinking BltByKrmn 5th gen T4Rs 28 02-22-2024 10:39 PM
Blinking A/C light? KYBubblehead 4th Gen T4Rs 3 05-29-2018 04:03 PM
4 x 4 Blinking ….. HELP NEEDED Magiclamp2012 3rd gen T4Rs 15 11-09-2011 11:59 AM
O/D blinking on and off DSpease15 Maintenance/Detailing 4 12-10-2010 12:00 AM
A/C Blinking~ t65k3 4th Gen T4Rs 4 07-07-2008 05:19 PM
