12-27-2023, 09:58 AM
Best oil filter for '05 SR5?
My '05 SR5 has 179k miles. I change the oil & filter every 6k miles or so. I use Amsoil oil and their Wix filter.
Which oil filter does this forum recommend? I may begin replacing the filter every 2-3k miles just to be mega-extra certain the engine is using clean oil.
Thanks.
12-27-2023, 11:45 AM
Toyota oem filter: 90915-yzzd3
'08 Silver SR5 V6 4x4: OEM+
12-27-2023, 05:10 PM
Real Name: Skip
Real Name: Skip
OEM, it's the best filter you will find and it's not expensive
2004 Limited V8
12-27-2023, 09:28 PM
Real Name: Ron
Real Name: Ron
Yep, I only use Toyota oil filter.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
12-27-2023, 09:41 PM
An old post of mine......
Ebay for $44.90, free shipping.
90915-YZZD3, Qty 10, Toyota \ Lexus Oil Filters With Drain Plug Gaskets
eBay item number:252829995054
Like I said......an old post......but you get the idea.
Kevin
12-28-2023, 07:12 PM
I’ve always ran the TRD filter. PN - PTR4300080.
Better filter than OEM but can be pricey from stealership.
12-28-2023, 10:16 PM
Originally Posted by Berty_K
Or you can confirm that you are buying from a Toyota dealer.
Kevin
01-01-2024, 11:52 AM
Real Name: Russell (OB #9908)
Ten-packs of OEM filters can typically be had on parts.toyota.com for ~$4 each. I order them from a local dealer who discounts their online orders (some do, some don't) and pick them up. For parts and such, a standard I use is not just to look at differences, the key is significant, measurable differences. This filter or that filter, oil, whatever - does the price and/or inconvenience provide enough of an improvement to justify that choice? Most times, not. I buy OEM whenever the price is competitive or even close but currently have 1A Auto LCAs and just bought their ignition coils and tie rods.
01-03-2024, 11:43 PM
OEM, they're like $5
pet every dog
01-14-2024, 11:15 PM
oem, i buy sets on ebay or amazon, usually 5-10, they come out to like 6 dollars a piece
