Old 08-24-2022, 05:39 AM #1
08tnt 08tnt is offline
08tnt is on a distinguished road
Fuel pump
About how many miles will stock fuel pump last? I have 190k on the clock on my 08.
08tnt is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 08:15 AM #2
NCrunner2012 NCrunner2012 is offline
NCrunner2012 is on a distinguished road
I think it's pretty subjective, but I replaced mine at 220k
1998 T4R Limited 4x4- Sold
2005 T4R Limited 4x4 V8
NCrunner2012 is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 08:17 AM #3
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
My 08 has 209k on it and mine is starting to show signs of failure.
Another members thread described similar issues with 230k.
Not an exact number but many other seem to be north of 180k when they do a replacement.
PN for the 4th gen is 7702035112
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 08:42 AM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I replaced mine at 220,000 preventively. Its better to do it when you have time than when you get stranded
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 08:51 AM #5
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
My fuel sender failed (gas gauge was all over the place) at 180k miles. There was no way I was only replacing the fuel sender if I had to drop the gas tank, so I replaced the sender and the fuel pump.
Make sure you replace the filter as well if you do it, and use a Denso (OEM) filter.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 08-24-2022, 07:33 PM #6
Thank everyone for the reply. I was thinking about the preventative maintenance so as to not be stranded. Lol
Old 08-24-2022, 07:34 PM #7
Timing chain / belt
This is my next question. When to replace them.
Old 08-24-2022, 11:05 PM #8
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
if made by Denso, can it be purchased without the Toyota mark up? and, is this a DIY job? i saw a tube video the showed an access port under the rear driver side carpet that allows you to unplug the pump electronically. in this video, they also cut the thin floor sheet metal to lift the pump out without dropping the tank (i am not recommending that method!).
rwh963 is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 10:13 AM #9
Definitely a DIY job. Difficulty totally depends on the level of rust you've got. If your rust is minimal, and you can get all the gas out of the tank before swapping it, its really not that bad. You undo the straps, lower the tank, disconnect the hoses, and then pull it out and service the pump.
To clarify, I couldn't find an OEM fuel filter. Had to buy the entire assembly for that ($$$$$). However, you can get a Denso fuel pump for 125$ from Rockauto.
Old 08-25-2022, 12:10 PM #10
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is online now
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
In case any of this is helpful, I cut and pasted my post about the recent replacement of my '07's fuel sending unit at 228K miles. I replaced the fuel pump as well since the tank had to be dropped anyway. As noted, I elected not to DIY it. While many have, it turned out to be a good call b/c the Denso fuel pump I ordered was missing an o-ring and wouldn't hold pressure. The repair shop had to drop the tank again to install the o-ring. YMMV of course. I would not recommend trying to cut the floor access larger, first b/c it's just not a good idea and also b/c the sheet metal there has numerous creases and reinforcements that would make cutting problematic. Here's the post:
Had my fuel sending unit replaced and did the fuel pump for good measure while the tank was out. The video at the end of this post by someone named Rick S. provides an impressively detailed analysis of the issue, the short version being that I recognized a number of the symptoms described have been going on with my truck for years. Recently it started reading 1/4 tank low all the time. I'm keeping this truck forever so I fixed it and wanted to provide some pics and info.
For reference, my 4R is an '07 V6 with ~228K miles.
Cost: Parts ~$283 | Labor $393 with 10% veteran discount makes the total ~$676. Yeah, a lot of money, but probably about a month's car payment on a new vehicle so there's that. Someone comfortable doing the job themselves could do it for about $250 worth of parts (fuel pump kit, fuel sending unit, and the housing with the filter media and even that's kind of optional).
Chokes me to pay the labor but after consideration of the job itself and other things going on, it was worth it.
Parts list. OEM items are from Cobb County Toyota's online store.
8332060440 $ 95.70 GAGE ASSEMBLY, FUEL SENDER
2330050120 $ 37.97 Fuel Filter << This is the housing w/filter media in it
7714435010 $ 33.59 Fuel Tank Lock Ring << Didn't necessarily need
7716904050 $ 6.34 Fuel Pump Tank Seal << Gasket
Denso fuel pump & mounting kit - ~$109 from Amazon
Here's a comparison of the fuel sending units and the problem is obvious - the "track" where the end of the float arm moves gets worn away over time.
Old:
New:
Interestingly, the 4th Gen fuel filter has two components. There's the strainer, which I have to say looked pretty clean for the age and mileage.
Old:
New:
Then the housing itself has filter media inside, visible through the hose connections in this pic of the new one. I unfortunately couldn't get a pic of the old one but it was nearly black.
Here's the video by Rick S. Worth watching if you're having these issues or just want a very thorough understanding of the fuel sending unit and how it works.
Bluesky 07 is online now   Reply With QuoteReply With Quote
Old 08-25-2022, 04:00 PM #11
excellent contribution. many thanks!
Old 08-25-2022, 05:19 PM #12
i have been experiencing power hesitation for several months now, at 230k. i've driven the 4runner as owner for about 4 years. i tend to keep the tank at about 1/2 full, running it to 1/4-warning light, then back to 1/2. i see the wear zones on your old pump. mine probably has the same in the 1/2-0 zone, and that is why the pump is working normally at a full tank vs a low tank.
if i keep it in the 3/4-full zone i will probably be good for a while until replacement. great and timely write-up!
Old 08-25-2022, 05:37 PM #13
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
That wear you're seeing on his old sending unit would only affect the gas gauge accuracy, it shouldn't have any affect on how the engine runs, only the pump itself and or the filter would affect how the engine runs!
2004 Limited V8
Old 08-25-2022, 06:24 PM #14
i see. well, my gauge seems to work normally, and the truck has never stalled or failed to start.
Old 08-26-2022, 01:55 PM #15
Drcoffee's Avatar
Drcoffee's Avatar
Yes, rockauto has the denso pump.
Fuel pump-2df3c295-d323-4c29-b4aa-ba7cf2d95097-jpg
190k , clock , fuel , pump , stock
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
Fuel Pump Relocation? or Fuel Pump Hatch? Cygnus 3rd gen T4Rs 3 01-24-2022 03:06 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
