Old 09-01-2022, 08:35 PM #1
harojs harojs is offline
harojs is on a distinguished road
Moonroof - removal instructions
My 2006 4Runner moonroof is jammed.
Motor works, but get loud gear skipping noise when try to open or close.
I loosened the headliner and can get to inside bolts of the moonroof.
I want to remove the whole moonroof assy and see if I can lube tracks outside of vehicle if I find a track jamming.
Need procedure to remove the whole moonroof assy from vehicle.
Would like to carefully spray the tracks with lithium grease outside of vehicle.
Passenger side is free - driver side seems jammed.
Ideas?
John
Bellevue, WA
harojs is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 08:58 PM #2
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Ideas?
John
Bellevue, WA
Did you drop the headliner? I have a jammed sunroof (in closed position) and my research led me to believe the whole headliner needed to be removed before moonroof r/r was possible?
Happy to dig up links I've saved as well if helpful.
eleven14 is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 09:11 PM #3
Yeah, I had to loosen the entire headliner so I could just get some free play around the moonroof assy.
I didn't have remove the headliner, just make it loose. Still, had to unclip all the trim panels.
A PITA, yes, but not too bad.
Old 09-01-2022, 09:13 PM #4
I am thinking I can lube some things if I could get the glass to fully retract.
Any ideas on how to do that?
Do you think my cables are stuck?, or part of the track is stuck?
I live in PNW, so things are not much rusted.
Old 09-02-2022, 01:40 PM #5
Very common that the cables seize inside the channels they run through. In my case, after removing the motor, I could slide the glass all the way open with my hands. Yet, when reassembled, it would make that clicking sound when sliding to "full open" (which I think is the final adjustment that raises the wind deflector).
Are you able to fully open the moonroof by hand with the motor out? This post has a ton of useful reference.
Old 05-01-2024, 08:42 PM #6
Couldn't disconnect front of headliner
I never got my moonroof fixed because the headliner had some wires on the drivers side that I could not disconnect.
I may have to buy the track parts so I need to remove the headliner entirely.
I'm getting ready to try this again.
[Q] How do you disconnect the wires from the headliner to the dashboard? There does not seem to be a wire disconnect plug. The headliner wires just disappear into the firewall/dashboard.
Old 05-02-2024, 08:11 AM #7
parsky1 parsky1 is offline
parsky1 is on a distinguished road
Mine started the infamous grinding when closing. I got it closed and disconnected the switch wires in the connector up behind where the sunglasses holder is. You just pull two crimps out of a connector and tape them up. It was the green and gray wire. The red is power for the lights and the two whites are grounds I believe.
parsky1 is offline   Reply With QuoteReply With Quote
Old 05-02-2024, 12:17 PM #8
Wires taped to the headliner
Thanks Parsky,
I need to totally disconnect the headliner and remove it from vehicle.
This will allow me to see if I can free up or replace the moon roof cables.
Problem now is there is a small wire bundle that is taped to the headliner.
Disconnecting at all the various OEM taped connections on the headliner does not seem right.
I heard somewhere that there is a main disconnection plug for the headliner harness that comes down the drivers windshield post into the firewall or instrument cluster so I can remove the entire headliner with its single pigtail harness?
[Q] Where is this main headliner connector? I can't find it in the firewall or fuse area behind the drivers side instrument cluster.
Old 05-02-2024, 05:40 PM #9
Here's a pretty thorough description for removing the headliner I had bookmarked for (someday) fixing my sunroof. If you get in there, take pics/notes for the rest of us!
assy , moonroof , remove , tracks , vehicle
Looking for Liftgate / Tailegate Removal Instructions (Whole Assembly) Flash Runner 4th Gen T4Rs 13 05-14-2020 12:28 AM
Back Window Panel Removal Instructions Franky_Dabbs 3rd gen T4Rs 3 04-16-2015 10:57 AM
4th Gen stereo removal/install instructions Djrashonal Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-16-2013 03:20 AM
instructions for 2d gen gauge cluster removal bills86e Classic T4Rs 4 12-22-2012 05:31 PM
EGR Valve removal instructions for 95 4runner, can anyone help? itsgt Maintenance/Detailing 0 12-02-2004 12:04 AM
