Old 12-12-2022, 08:25 PM #1
Ron_Mexico Ron_Mexico is offline
Ron_Mexico is on a distinguished road
Oil leak on engine near dip stick, should I be worried?
Today I was checking my oil and noticed that it looks like oil is leaking through gasket, near the dip stick. Should I be overly concerned? Is this a normal issue that needs to be looked at?? I attached a picture showing the problem area. The other side of the engine appears to be dry!! My 4runner is a 2006 V6 Sport 4WD.
Oil leak on engine near dip stick, should I be worried?-c448b6b9-c85e-4fed-af4c-1eaf0f1ced15-jpeg
Ron_Mexico is offline   Reply With QuoteReply With Quote
Old 12-12-2022, 11:39 PM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Looks like a valve cover gasket to me.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 12-13-2022, 07:07 AM #3
Is this a common issue with 4Runners? Anyone get this done and is it an expensive fix??
Old 12-13-2022, 09:33 AM #4
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
super easy fix, youtube the video. all your replacing is a rubber gasket.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 12-15-2022, 01:26 PM #5
dcraddo03's Avatar
dcraddo03 dcraddo03 is offline
Real Name: Daniel
dcraddo03 is on a distinguished road
dcraddo03's Avatar
Real Name: Daniel
Agree.
It's not hard to fix. Just need a few sockets and 2 hours or so. If you have a V8 (not sure if this applies to v6 owners or not), you'll need to remove the airbox to have space to work on the passenger side valve cover. You can find a gasket kit at your local parts store.
Don't forget to do your half moons and coil cylinder gaskets!
'06 Sport V8 RWD | OME 885's on Bilstein 5100's | JBA UCA's | Doug Thorley Long Tubes w/ Magnaflow Catback | Satoshi Grille Mod | Oracle Halo Kit | TRD Pro FJ Wheels | Sony XAV-AX100 w/ Rockford Fosgate 10" Punch Subwoofer | BF Goodrich KO2's (275/70/17) | 15% Tint | 282xxx miles
dcraddo03 is offline   Reply With QuoteReply With Quote
Old 12-15-2022, 05:48 PM #6
Originally Posted by dcraddo03 View Post
Agree.
I’m not familiar with what/where half moons and coil cylinder gaskets are. I better do more research before taking on this job myself. Thanks for the reply!!
Old 12-16-2022, 08:30 AM #7
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
A couple of things. First, this is typically a very simple repair that anyone with a few tools and some basic mechanical skills can tackle. But, I've seen several posts on here from people who were attempting this repair and had multiple bolts break while trying to remove them. Considering you list your location as The Great White North I would think that could very likely happen to you. That would open up a whole new can of worms if it happens. Depending on which bolt breaks, (if one does), it could be a difficult extraction. Because of that, and the hesitation I see in your post, you probably would be better off taking it to a shop. The other thing is, it appears to be a fairly minor leak. I think I would just clean it off good and monitor it for a while. Keep a check on your oil level and don't let it run low. (I seriously doubt it's going to drop much from this.) If it's like I think, you could probably run for years like this without any problems unless it gets worse. Just clean it occasionally. At some point the other side will probably start leaking too and you can just have them both done at the same time. JMHO
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 12:11 PM #8
I think I’ll take your advice, I’ll clean the area first and assess my next move once the weather is better in the spring. Thank you!!
Old 12-17-2022, 03:11 PM #9
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
It's good advice. What's the recommended approach if moving forward on one's own? PB blaster said bolts for a few weeks in advance and hope for the best?
eleven14 is offline   Reply With QuoteReply With Quote
Old 01-18-2023, 08:51 AM #10
Real Name: Danny
Real Name: Danny
That's what I would do.
Old 01-19-2023, 04:26 PM #11
Whamola Whamola is offline
Whamola is on a distinguished road
Check to see if they're even tight. My drivers side started leaking. I could smell the oil after it warmed up. Turns out almost all the bolts were inexplicably loose. Tightened down and don't smell it anymore. Gonna get in and clean it up and be sure once it's not miserable cold.
Whamola is offline   Reply With QuoteReply With Quote
dip , engine , normal , oil , stick
5th Gen Engine Oil Leak at 50k assassin 5th gen T4Rs 62 01-05-2023 09:48 PM
V8 Engine Leak beach146 4th Gen T4Rs 16 01-31-2018 04:26 PM
Possible engine oil leak? Auce 3rd gen T4Rs 5 04-09-2014 08:28 PM
I'm worried this mechanic is trying to screw me - '95 4R engine ticking ssccchef Classic T4Rs 14 11-02-2009 12:03 PM
Transmission Leak - Dip Stick Assembly smallbrian 4th Gen T4Rs 5 01-07-2009 09:12 AM
