Old 03-06-2023, 09:48 AM #1
MityMax96 MityMax96 is offline
MityMax96 is on a distinguished road
Transmission issues and questions
Hello all,
I have been noticing I guess what would be "slipping"
It happens around 45mph when it shifts
So the shift will begin, engine revs up for a second, I let off the gas and the then it completes the shift, and RPMs return to normal.
So question:
1) Should I do a transmission fluid flush? (Following this thread: DIY: Non-Sealed Transmission Service for 4th Gen T4R's and Prior)
2) Replace the solenoids? If so, if I do the flush in the thread mentioned above, will I have access to the solenoids to change them out?
Thank you for your input
MityMax96 is offline   Reply With QuoteReply With Quote
Old 03-06-2023, 10:16 AM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Hello. More info might be helpful.
How many miles on your truck?
What type of service has the transmission had? Original trans fluid?
zguy1 is offline   Reply With QuoteReply With Quote
Old 03-06-2023, 10:30 AM #3
I am over 200k
I bought it used about 5 years ago....
I have done none on the truck myself.
I have no idea if any was done w/ previous owner. So I am going to assume none has been done and the fluids are original.
I had an old Silverado...and did a transmission fluid flush on it, and that made a noticeable difference in shifting
So I am thinking it might be similar for my 4Runner.
Old 03-06-2023, 10:59 AM #4
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Fluid is getting old and breaking down. Do a fluid exchange now while you still have life in it. Several ways to go about it.
I did a procedure like this: https://www.youtube.com/watch?v=WngXE_7vg-Q&feature=youtu.be
It's been several years and thousand miles. I used Maxlife fluid. Shudder I had at the time went away and all has been fine since then. No I didn't open up the pan or replace the filter. There was debate on this that it's not necessary due to being a metal screen type. Like the video, I just kept repeating the process until I had fresh red fluid coming out.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 03-06-2023, 11:04 AM #5
zguy1's Avatar
zguy1's Avatar
Okay. I would have said try a drain and fill but maybe maybe you should consider a full fluid replacement. I'm not sure if it is warranted to replace the filter with your first attempt.
I am sure others will chime in.
Old 03-06-2023, 11:13 AM #6
Thank you gents for your input.
I will give it a go and see what happens.
You don't think the solenoid should be replaced?
Old 03-06-2023, 11:39 AM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I'd start with the most conservative course of action and go from there. The conventional wisdom here is a full fluid exchange - not flush. A flush uses pressure and you don't want that. There are numerous links here and I think some YT videos on doing the exchange using the cooling lines and such. I've done mine twice.
About the fluid, some people swear by Maxlife and it's cheaper than Toyota WS. Maybe it's fine, but a fluid that claims to meet the specs of many different manufacturers and transmissions seems too good to be true. This isn't like coolant, where aftermarket long-life red is specific to a range of Asian vehicles; Maxlife supposedly works for everybody. Plus, the guy in the video seems to know a thing or two about the topic and emphatically says ATF is not a one-size-fits-all proposition.
There's no maybe with WS - I know it works. Granted, my take may be different b/c I intend to drive this truck until one of us can't get out of the garage anymore. Your truck, your call, but that's my 2 cents.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-06-2023, 04:21 PM #8
Ok, I will go the route of draining and filling the fluid first.
I was going to go ahead and pay for the Toyota 00279-000T4 Automatic Transmission Fluid,
I believe this is the correct one for this 4Runner?
$50 for 192 ounces.
Old 03-06-2023, 07:27 PM #9
Bluesky 07's Avatar
Bluesky 07's Avatar
$50 for 192 ounces.
According to this post, that is the correct fluid IF your truck has a transmission dipstick. If there’s no transmission dipstick, it uses WS fluid. Please double-check before going ahead since the process may be different too. People say a full exchange takes varying amounts, typically always at least 12, and personal experience has been 14 quarts on my ‘07.
Also, consider ordering the fluid online from a dealer with an online parts department. Many offer significant discounts, some with free shipping (or you can pick up locally if convenient), and you’ll know for sure it’s genuine OEM fluid. Site is parts.toyota.com and be sure to check several dealers as they set their own prices.
Old 03-06-2023, 07:42 PM #10
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
$50 for 192 ounces.
As mentioned that maybe the correct fluid or not, you don't want to use it if it's not the correct fluid.
For us to confirm which fluid you need we need to know what year model you have and engine you have would also help!!
2004 Limited V8
Old 03-07-2023, 07:48 AM #11
I do have a dipstick.
I will look around as you suggested.
Old 03-07-2023, 07:49 AM #12
It's the 4.0 L engine I have, with a dipstick.
Is there somewhere on the engine I can get the exact model?
Old 03-07-2023, 08:15 AM #13
zguy1's Avatar
zguy1's Avatar
Do you still have your owners manual? The fluid type is specified in there. At the end of the manual, in the specifications section.
Fluid type:
Toyota Genuine ATF WS
Old 03-07-2023, 12:58 PM #14
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
The dipstick should also say Type-IV on it.
When I did mine I changed it with Amsoil signature series ATF. Its been a few thousand miles already with no issues at all.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 03-07-2023, 02:28 PM #15
Fluid type:
I will look and see
I bought it used, so it may not be with the vehicle.
flush , shift , solenoids , thread , transmission
Some transmission issues... P40Wolf 3rd gen T4Rs 2 11-02-2015 09:57 PM
99 transmission issues Beagle(4)Runner 3rd gen T4Rs 14 02-22-2015 09:46 PM
transmission issues need help Park 3rd gen T4Rs 3 07-04-2014 01:08 PM
TRANSMISSION ISSUES i think? 89yota4x4 Classic T4Rs 3 06-09-2013 12:00 AM
Transmission issues rtuck1 4th Gen T4Rs 3 07-26-2011 09:54 AM
