Quick help--Trans fluid what nozzle to refill ?
ms0072
So I drained a few quarts of transmission fluid yesterday and this morning I went to refill it . I didnt anticipate how small the fill hole is and that you need to have like a right angle on the end of whatever you are using to refill to prevent the fluid from just dripping down the refill tube. I have a pump but I havent been able to find anything that will work that fits in the hole and has a bend.
Does anyone have any info on what they used ?
I am supposed to be leaving for a long drive today -- hoping someone has done this and has some info on what they used.
Thanks
If you are talking about trying to refill through the trans dipstick tube, there is a special funnel available at auto parts stores that fits in side the tube. If you don't have a dipstick tube then you have to refill through the fill port on side of trans I believe. I don't know what that takes.
maybe you need to make your own, some metal brake lines that you can bend and a hose that is the correct size so you can adapt to your pump.
or you can use some hose on the bottle nipple, and point that to the fill hole, poke a small hole at the top of the bottle, and use your air compressor and blow air to the bottle.
