Old 05-16-2023, 02:30 PM #1
Texas4run Texas4run is offline
Texas4run is on a distinguished road
Anyone fixed a cracked dashboard?
So my 2005 4runner Sr5 have a few cracks in the dashboard. I have started to get really tired of looking at them and trying to find a way to fix/improve the dashboard.
I know about the recall in the past. At the time I actually didn't have a single crack. In other words it is the original dashboard from 2005. I looked at the so called overlay options but it doesn't seem like an option.
Has anyone figured out a way to fix a cracked dashboard? It must be something out there that can be used? Paint, plastidip, filler or whatever.
Any input is welcome.
Thanks
Matt
Texas4run is offline   Reply With QuoteReply With Quote
Old 05-16-2023, 05:29 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm afraid there's probably not a way to repair the cracks, especially a way that will last.
You could try a vinyl repair kit, the reviews for most of them is not all that great but you may get lucky and it works for you.
Amazon.com
I would suggest checking some of the local salvage yards in your area and you may get lucky and find one that was replaced under the extended warranty.
2004 Limited V8
Old 05-16-2023, 06:29 PM #3
Amazon.com
Thanks for the response. I looked at a few local salvage yards but the dashboards are not that great, or at least not worth the work of replacing the current dashboard with.
Found this, not sure if I want to invest this into a 05 with 248K miles.
55401-35909-B1 Genuine Toyota Part)
Old 05-17-2023, 01:18 AM #4
d33pt d33pt is offline
d33pt is on a distinguished road
Doesn't seem like it would be worth the work at that age and mileage. Even if the part was free. It probably won't change resale value much.
d33pt is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 05:30 AM #5
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
I wouldn't replace it with a salvage dash, chances are its gonna crack too.
If you want a permanent problem free fix, you need to take the dash apart and take it to a upholstery place. Wrap it in some nice leather/vinyl.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 06:02 AM #6
Real Name: Skip
Real Name: Skip
While that is an option, I would think it may cost you as much as just buying a new dash cover from Toyota, but that should be done sooner than later because there doesn't seem many available and Toyota will not be making any more at this point, any you find now are likely left over from the "Extended Warranty".
2004 Limited V8
Old 05-19-2023, 12:32 PM #7
Thanks for the replies. I might just have to live with the cracked dashboard.
Old 05-19-2023, 03:53 PM #8
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
If it really bugs you you could try something that's strong with a bit of pliability like liquid nails. Put a bead just big enough to fill the void then shave it down once it dries. Then spray some paint or maybe put shoe polish on it. Just trying to think outside the box.
On my truck someone glued something to the dash and made a 2" round ugly divot in it. I used black shoe polish to blend it in. Doesn't bug me anymore.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-19-2023, 04:32 PM #9
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I thought I read somewhere where some Lexus IS300 guys were filling in the cracks with glue or foam, shaving smooth, and rewrapping or painting I cant remember exactly.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 05:54 AM #10
miller507's Avatar
miller507's Avatar
I mean depends on how long you're planning on keeping it, I did that back in 2012 when I first bought my 4th gen payed around 300 bucks for the whole job (dash removal/upholstery). Since the dash was out I changed the evap core too.
There was a time you could buy some sort of dash cover that still looked oemish that sat on top of the factory one.
LC Prado 150
4th Gen 4Runner
1GR-FE
Old 05-20-2023, 09:38 AM #11
I think this might be what you are referring to.
Coverlay
I have considered plastidip, still waiting for an answer from the "Plastidip company". I have used it in the past on smaller items but not on a whole dashboard.
DipYourCar - World Famous Peelable Auto Paint – DipYourCar.com
cracked , dashboard , figured , option , options
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
ZE6 CSP/TSB Information for Cracked/Sticky Dashboard BlackWorksInc TSB 19 01-12-2017 01:24 PM
My Cracked Dashboard HanginInUtah Classic T4Rs 12 02-04-2015 07:13 AM
Recovered 2004 Cracked Dashboard kylebacc 4th Gen T4Rs 0 12-07-2012 01:27 PM
Cracked Dashboard sr1982 4th Gen T4Rs 3 09-10-2010 09:27 PM
