Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 08-04-2023, 12:04 AM #1
mjlmjl mjlmjl is offline
Junior Member
mjlmjl is on a distinguished road
Junior Member
Power steering fluid reservoir
Hi,
I have a 2007 4Runner at 430,000km (260,000mile).
The power steering is starting to be difficult to turn and so I’ve looked up various posts and vids to flush and completely replace the fluid.
The question I have is - does the PS fluid reservoir have a filter located at the bottom? Is it advisable to also change this plastic reservoir if it does have a filter? It costs about $80 cdn.
Anyone have experience or advice?
Thanks.
Mjl
mjlmjl is offline   Reply With QuoteReply With Quote
Old 08-04-2023, 12:08 PM #2
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Senior Member
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Senior Member
Bluesky 07's Avatar
Quote:
Originally Posted by mjlmjl View Post
Hi,
Thanks.
Mjl
The reservoir doesn't have a filter in it. Some have installed an inline filter when doing a fluid change, for example a Magnafine. Something unexpected that I discovered after buying my '07 is that 4th Gen 4Runners don't use power steering fluid in their PS reservoirs. Seems odd but it's true - the spec fluid is actually automatic transmission fluid - but not what you use in the 4Runner's transmission. Not weird at all, right? From the 2007 manual:
Check the fluid level through the reservoir. If necessary, add automatic transmission fluid DEXRON II or III.
If the vehicle has been driven around 80 km/h (50 mph) for 20 minutes (a little more in frigid temperatures), the fluid is hot (60C—80C or 140F—175F). You may also check the level when the fluid is cold (about room temperature, 10C—30C or 50F—85F) if the engine has not been run for about five hours.
If the fluid change doesn't help, search the forum for 4th Gen stiff steering threads. Could be an issue with the steering shaft itself.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-04-2023, 04:01 PM #3
MikeinNH67's Avatar
MikeinNH67 MikeinNH67 is offline
Senior Member
Real Name: Mike
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
Senior Member
MikeinNH67's Avatar
Real Name: Mike
Quote:
I would focus here first as it's a common issue. Simple check, jack both front wheels off the ground and try turning the wheel with the key to on but engine off. If it's hard and notchy lock to lock then the steering shaft u-joint is most likely freezing up. It should be easy and smooth.
__________________
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
MikeinNH67 is offline   Reply With QuoteReply With Quote
Old 08-08-2023, 02:12 PM #4
Junior Member
Junior Member
Thanks Bluesky and MikeinNH for your suggestions.
I have since partially changed the ps fluid. I pumped out the fluid from the reservoir and refilled. Started up engine, turned wheel left and right. Then pumped out fluid again and refilled. The old fluid was very dark, almost black and smelled burnt. I just replaced 2-3 cups. Used DEXTRON transmission fluid.
The initial results were not significant. Power steering was still heavy and then the turning action felt ”lumpy”. It was a struggle to turn, then it got momentarily better,then it was heavy turning again, etc..
Now after 4 more days of this, it back to normal. Works perfectly fine now. Problem has gone away.
The new reservoir has arrived, so I plan is to completely change out the ps fluid and switch out the old reservoir.
Will update…
Old 08-15-2023, 07:12 PM #5
Junior Member
Junior Member
UPDATE: Bad news...
Ok - so I've completely flushed the PS fluid and replaced it with DEXTRON AT fluid. The reservoir with pretty dirty and blacken inside, and since the new reservoir arrived - I decided to also replace it.
I'm totally disappointed now.
The power steering is actually hearvier and stiffer to turn the wheels. It feels "lumpy" when turning, as if it has notches in the rotation of the steering wheel. It takes a lot more effort now than ever before.
What's next? Is the U-Joint something I can "fix" or does it need to be replaced? Some threads mentioned scrapping away any rust and lubricating the joint... Would this be my next step?
Any suggestions?...
Old 08-15-2023, 09:56 PM #6
AuSeeker AuSeeker is offline
Senior Member
Real Name: Skip
AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future AuSeeker has a brilliant future
Senior Member
Real Name: Skip
UPDATE: Bad news...
Any suggestions?...
No you can't "fix" the u-joint, you can however replace the intermediate steering shaft which has a new u-joint on it.
You can spray it down thoroughly with a penetrating oil/spray and see if it frees up the steering some as a test, if that frees it up then the u-joint is definitely bad and you need to replace the shaft.
__________________
2004 Limited V8
AuSeeker is offline   Reply With QuoteReply With Quote
Old 09-28-2023, 11:22 AM #7
aa040371 aa040371 is offline
Member
aa040371 is on a distinguished road
Member
@mjlmjl : I am planning on a PS flush as well and would like to remove and clean my reservoir at same time. Did you use any write-up or manual or Youtube video or whatever to help you remove and then re-install the reservoir? Or is it so easy, i.e. just the three bolts, that a how-to was not needed?
Thanks...
__________________
2007 4-Runner Limited, V6 w/RWD.
aa040371 is offline   Reply With QuoteReply With Quote
Reply
Tags
filter , fluid , power , reservoir , steering
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power Steering Fluid Reservoir Bolts ryrobertson 4th Gen T4Rs 5 10-28-2020 03:14 AM
Power steering reservoir turned black Rayh78 4th Gen T4Rs 9 02-02-2020 12:23 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Power steering fluid reservoir hose clamps rusted karyins 4th Gen T4Rs 5 06-09-2016 08:16 AM
Power Steering Reservoir heatherlrader 4th Gen T4Rs 9 04-08-2016 11:54 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
