08-16-2023, 03:19 PM
What suspension to get in 2023?
I've been a little disconnected from the T4R community recently, and wanted to hear your thoughts on what suspensions everyone recommends in 2023 for their 4th gen.
I currently have Icon 2.0s, Icon UCAs, Icon rear coils, Icon rear shocks.
I wanted to upgrade to Icon 2.5 extended travel to get more height.
I personally do like the Icons, but wanted to hear what other options are out there.
I know people are using Dobbinsons and some other options.
My plan is to essentially tear apart my front suspension and replace everything with new coils, shocks, bushings, CVs, etc.
Interested to hear your thoughts as to the route you would take.
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
08-16-2023, 04:43 PM
Real Name: Todd
Real Name: Todd
Get your height from larger tires, not from the suspension. You run into all sorts of issues by trying to get more height from the suspension.
It all comes down to your intended use. Rockcrawling, overlanding, mudding, mallcrawling? Where does the truck spend the most of it's time?
I do a bit of everything and went with ADS for the shocks and run MetalTech HD Extended travel coils in the rear and it all works great for overlanding and mild rockcrawling.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
08-16-2023, 04:54 PM
ADS and Fox use the best quality parts...If I were to do it all over again, I'd go that route, with ADS holding the number 1 slot...tall and skinny tires are the best for lift and boy does it help on longevity and function!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
08-17-2023, 08:17 AM
Real Name: Ron
Real Name: Ron
Shock Surplus puts out some good comparison videos, I just watched their " King Shocks vs. Fox Shocks vs. Icon- Baseline off the shelf Behaviors" check it/them out.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
08-17-2023, 10:29 AM
Real Name: Russell (OB #9908)
This is a tough question b/c 1) ride and handling are subjective (my awesome might be your terrible and vice-versa), and 2) you can spend a lot of money on gear you can't really return. I have had "Tacoma swap" components (very cost effective and nice low-mileage OEM parts, worked great) and currently have Eibach, which I think is a superb value with outstanding on- and off-road manners. My sig has a suspension link that may have some helpful info.
