Originally Posted by Bob22222
I was hoping to get off cheap with sway bar bushings. No way. At least one of my lower control arm bushings is shot. I figure I should do it all.
The way I see it I should replace all four front control arms and ball joints.
The choices range from cheapo Chinese (ha ha no way for this guy) a complete kit from Walmart for about 200 dollars to toyota control for about 1,000 dollars.
I'm thinking moog from rockauto.com is likely my best bet. Which I believe will come in at just under 500 dollars plus tax shipping.
Any suggestions will be greatly appreciated. As well as a link to a good write up on the r&r process from the experienced
Thanks, Bob
I'm not sure what skill level you're at mechanically. There is nothing wrong with your $1000 OEM lowers. So wouldn't you want to keep them and just press in new bushings instead of buying a cheap arm. I replaced all four lower arm bushings for $80.. from Walmart. I was skeptical on quality so I researched the product. They are German engineered, they know their sh1t. They are the same as OEM on the durometer scale (spring rate). They feel like new OEMs now. Also have a year warranty. Here's a picture of them for my 2010. Might wanna take a look at them for you year model.
