09-20-2023, 01:15 AM
What Lower Control Arms Are You Using?
I'm looking to get a new set of LCAs. Current set bushings are worn and looking to get something to alleviate all my issues I currently have with them.
What do you recommend?
Knightsfs4 Build Thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
Jack-Purchased on 11/22/10- 2006 Limited 4X4 V8
09-20-2023, 10:40 AM
I put Whiteline LCA bushings in my OEM control arms, nice and tight again.
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
09-20-2023, 10:36 PM
Originally Posted by knightsfs4
Yep those are them
09-21-2023, 01:53 PM
Real Name: Casey
Real Name: Casey
Superpro bushings for me. Whiteline and Superpro are similar quality in my experience. I have a bunch of whiteline stuff on my track car. Can't go wrong with either.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
09-21-2023, 01:56 PM
Does Superpro sell the offset bushings they put in their LCAs?
09-21-2023, 02:02 PM
Real Name: Casey
Real Name: Casey
I believe so, yes. But I didn't get the offset ones.
09-21-2023, 02:26 PM
Real Name: Russell (OB #9908)
I bought LCAs from 1A Auto a year or so ago. Solid parts that look identical to OEM (though I know they're likely not equivalent). No issues at all. On another note, check out their YT channel for a pretty extensive set of 4th Gen installation videos covering various parts.
09-21-2023, 10:11 PM
Real Name: Casey
Real Name: Casey
Yep, those are the ones!
09-22-2023, 12:35 PM
Are the whiteline/superpro bushings OEM-ish or are they a bit more stiff and therefore potentially more harsh/noisy/nvh driving? I'm getting old so comfort is king!
For yall that replaced them - how bad was it getting the cam bolts/sleeves off? Seems like one should assume they will be seized completely...?
09-22-2023, 01:27 PM
For ~$300 more you get complete superpro arms with all the hardware and a new LBJ. Plus you don't have to mess with the bushing removal.
09-23-2023, 05:52 AM
Energy Suspension bushings going about 8 years and ac delco lbj
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
09-23-2023, 03:20 PM
Are these better than OEM though? For $600 you can get a brand new set of OEM LCAs.
09-23-2023, 04:16 PM
Rebuild with energy suspension or white line bushings and new ball joints. And then repaint the arms. You’ll save some money and it’ll be a nice upgrade
