Old 10-06-2023, 12:47 PM #16
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by Hi-desertT4R View Post
It should be noted that having new seals while in there is a good idea. When I messed my axle up I was removing it to install the ECGS solid bushing and seal. No issues with the seal leaking. The dust cap makes an excellent install tool for the seal behind the knuckle/bearing.
My passenger side inner seal is leaking after 16 years/150,000 miles and it’ll be the first time it’s ever come apart.
What I found difficult was knowing how deep to seat it. I saw some posts saying the depth has to be just right and I thought it was. But trying to get into position to really see into that space is hard to begin with, and I wear glasses so I also have to be able to get an angle where everything is in focus.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-20-2023, 01:26 PM #17
ace4aday's Avatar
ace4aday ace4aday is offline
ace4aday is on a distinguished road
ace4aday's Avatar
The Saga Continues
Originally Posted by Bluesky 07 View Post
The seal is what makes me reluctant to do it again. Thought I had it seated, double-checked, and all I got for my trouble was gear oil drops on the garage floor the next morning. Had to pay a shop to replace it.
First off, thanks for the help. It's been really wet here, but my wife I finally had opportunity to make another attempt.
Long story shortened...I bought the hub puller off of Amazon. The larger of the two fit, not great, but it worked. I cranked it down until it started bending and then applied some heat. When I cranked some more, the axle started moving. There was a pretty good band of rust on the splines. Problem solved? Of course not.
Getting the old seal out, I managed to gouge the diff with the seal removal tool. Luckily, it was mostly near the outer edge so I deburred the gash with some emery cloth, cleaned it up, put on a dab of high temp RTV, and installed the seal, and then a re-booted axle. So far, 2 days and no leak. Fingers crossed. But....
Now a have a scrape-scrape sound when turned hard right. We didn't hear it when reassembling everything, but it's there when driving. From the cab, it sounds like the back plate touching the rotor intermittently. We did bend it while working, but we had it bent back, I thought, so I'm not convinced that is it. We plan on putting it back on stands this afternoon to try and figure out what it it.
Stubborn CV Axle Help-pxl_20231019_155558536-jpg  Stubborn CV Axle Help-393818012_873623107681707_6888126106469893002_n-jpg
2008 Sport V6 in Salsa Red
Ironman 4x4 Stage 2 FCP Lift (2.5"/2")
Vision Manx II Wheels
275-70-17 KO2 Tires
Victory 4x4 Blitz Front Bumper
ace4aday is offline   Reply With QuoteReply With Quote
Old 10-20-2023, 04:10 PM #18
MikeinNH67's Avatar
MikeinNH67's Avatar
Good to hear that you got it off. The gouge is no biggie. My guess would be the backing plate too. There's some parts of it that run pretty close to the rotor. Hopefully it's that simple an issue.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-20-2023, 05:40 PM #19
Forum148 Forum148 is offline
Forum148 is on a distinguished road
Doesn't sound like this would have solve your problem but these are a pretty sweet tool to have in the toolbox.
GZila Designs | CV Removal Tool | Grab one today!
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 10-21-2023, 10:33 AM #20
ace4aday's Avatar
ace4aday's Avatar
No noise at all when up on stands, so I just pulled on the backing plate a little before setting it back down and sure enough, it's quiet! And still no leaks. I love this forum. Thanks again, everyone!
275-70-17 KO2 Tires
5lb , axle , ideas , mallet , side
Trying to remove stubborn #74 bulbs. Am I alone here? Mindomission 3rd gen T4Rs 14 02-01-2016 01:19 PM
stubborn o2 sensor aeb28 4th Gen T4Rs 18 07-24-2015 02:49 PM
HELP! Stubborn rear diff 88Cleve4runner 3rd gen T4Rs 10 07-10-2013 10:59 AM
stubborn dirt newbiemw Maintenance/Detailing 2 05-04-2011 09:43 PM
