Old 10-24-2023, 01:00 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
I installed a new battery and the engine is now throwing - P0171 -> P0101 -> P0138.
I installed a new battery and the engine is now throwing - P0171 -> P0101 -> P0138. Prior to the battery install I had never had a CEL come on since I've owned it. It's a 2008 with 180k miles on it.
I don't notice much other than little shake/knock at low RPM after starting up. Once it's warmed up, it seems to go away.
This is based off the scan from AutoZone
P0171 -System too Lean (A/F Lean, Bank 1)
Secondary DTCs
P0101 - Mass or Volume Air Flow Circuit Range/Performance
P0138 - Oxygen Sensor Circuit High Voltage Bank 1 Sensor 2
I replaced my MAF with a Denso (bought of Amazon and assume it's real). Any advice on what my next steps should be? Based off what I've read it could be a whole slew of things - O2 sensor, fuel injectors, manifold leak, or other vacuum leaks.
CO4x499 is offline   Reply With QuoteReply With Quote
Old 10-24-2023, 01:15 PM #2
SocalSam SocalSam is offline
SocalSam will become famous soon enough
I would be suspect of any "genuine" Toyota part from Amazon or Ebay. If you kept your old MAF and it still works, put it back.
SocalSam is offline   Reply With QuoteReply With Quote
Old 10-24-2023, 02:43 PM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I was sitting in a bank drive-thru with my '04 a number of years ago when about 3-4 lights suddenly lit up on the dash. I took it to the dealer and they said it was the O2 sensor. They said the sensor can cause other lights to come on. They replaced and reset the codes. It's been many years and I've not had any more lights come on, except low tire and when I trip the DAC by accident.
Since one of your codes is the O2 I would suspect that.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 08:55 AM #4
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Secondary DTCs
tried resetting the MIL, disconnect the battery for 15mins...then reconnect, start the car and relearn/idle for 7minutes
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
battery , p0101 , p0138 , p0171 , sensor
P0171/P0101/P0138 after installing new battery. I've replaced the MAF and gas cap. CO4x499 4th Gen T4Rs 0 07-18-2023 11:26 AM
Replaced battery today and now it's throwing CEL, VSC off, and Traction off. CO4x499 4th Gen T4Rs 3 02-11-2023 05:14 PM
throwing P0171 code ocreptileguy 3rd gen T4Rs 1 03-09-2015 06:12 PM
2001 T4R 3.4 Sputtering and throwing engine misfire in first 2 cylinders 501REPO 3rd gen T4Rs 9 09-06-2014 06:19 PM
CEL on, code P0101 after battery disconnect cloh09 4th Gen T4Rs 0 03-09-2014 05:46 PM
