Have your truck scanned. If those lights are on, then you should have codes in the ABS / VTRAC module. The generic or OBD-II may not have any codes since your check engine light is not on.
I have / had a similar
problem where occasionally I would get a flashing VSC and slip indicator light on. In one or more instance I had the ABS light on as well.
