Old 01-15-2024, 10:06 PM #1
dgbull3 dgbull3 is offline
dgbull3 is on a distinguished road
Fuel Leak - What’s this Hose?
Was backing down the driveway today when I noticed the smell of gas. Parked + popped the hood and noticed fuel dripping from this hose (see circled in red on photo). I moved around the hose clamps a bit and the leak stopped, but am not sure if it’ll come back.
What is this hose? Is it a regulator bleed off/return line? I couldn’t feel anything wrong with it. The only anomaly is that today was near 0F outside overnight before I started it. Not sure if that somehow contributed to the leak #shrinkage
-img_9071-jpg
dgbull3 is offline   Reply With QuoteReply With Quote
Old 01-15-2024, 10:42 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is online now
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Not sure if it's just me but the attachment isn't there.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is online now   Reply With QuoteReply With Quote
Old 01-16-2024, 12:58 AM #3
Sorry about that...for some reason the photo wasn't uploading from my phone. Got it working on the computer. The hose in question is circled in red, just under/behind the heater core supply + return. The clamp on the right was moved in the photo as I was messing with it (in case you spot that it's off its imprinted position just to the right of its current spot in the photo).
-img_9071-jpg  -screenshot-2024-01-16-12-12-11-am-png
Old 01-16-2024, 01:21 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I still don't see a photo/image
2004 Limited V8
Old 01-16-2024, 10:13 AM #5
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Your attachments are -jpg and -png. That's not the correct format for files. They should be .jpg or .png
dot, no dash.
Old 01-20-2024, 04:07 PM #6
dot, no dash.
I'm not sure why it did that. When I preview the post, it'll show the image but then it doesn't show up when I submit the post. Trying again...it's showing as '.jpg' in the attachment list.
-hose-leak-jpg
Old 01-20-2024, 04:13 PM #7
Well this is dumb... it shows up with the dot in my attachment list, but after I submit it, it changes the attachment to dash. I took a picture of it before submitting and verified that's what's happening.
In an attempt to describe the hose in question without the photo... it's on the driver's side, back top of the engine, immediately under the heater core supply+return hoses. The hose runs from the fuel rail there then by the master-cylinder/brake booster accumulator and connects to a hard tubing fuel connection.
Old 01-20-2024, 05:42 PM #8
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Sounds like part # 2327350040 - HOSE, FUEL, NO.2
23273C in the diagram here:
I think it's a return line that comes off the passenger side fuel rail, running behind the intake manifold. Not cheap at around $150, depending where you buy it. But it's a fuel line and you DO want to replace it if it's leaking.
It's the hose with the white clip in this pic of my engine.
Old 01-20-2024, 06:55 PM #9
Yup, that's the hose! i thought it must be some type of return since it just had hose clamps and would've been at a lower pressure perhaps. The leak was at the connection of clamp 23273D (there's two of these clamps). Since 23273C is a hose, I'm hoping the leak point is it versus the metal tubing of 23803B. Buying a replacement. Thank you!!!
fuel , hose , leak , noticed , today
Upper radiator hose leak texadelphia 3rd gen T4Rs 10 02-26-2021 09:36 PM
Intake Air hose leak: Temp fix? adder70 3rd gen T4Rs 8 07-11-2019 01:22 AM
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting 3rdgen_4runner 3rd gen T4Rs 2 09-05-2017 10:23 AM
Fuel Injector Hose leak - best temporary fix btruong25 4th Gen T4Rs 5 02-25-2016 05:11 PM
Coolant/hose/radiator leak 4Runnin Tahoe 3rd gen T4Rs 14 10-17-2013 07:05 PM
