Old 03-21-2024, 09:07 PM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
4.7L Ignition Coil Bolts
Does anyone know the Toyota part number for the ignition coil bolts? I found 90105-A0103 in the forum for someone doing a V6 but every Toyota parts site says it doesn’t fit. I also found in some exploded view drawings of a 2UZFE which show 91641-h0625 but the parts sites say those don’t fit and it shows a washer. Is it just an M6x1mmx25mm flange bolt on the V8 as well? I’m having a hell of a time getting mine out to measure. 6 point sockets just spin on the bolt head. Sockets measure .400”across the flats. Bolts measure .395” across the flats. Pretty puzzled…
parsky1 is offline   Reply With QuoteReply With Quote
Old 03-21-2024, 11:23 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You need to get better quality sockets!!
.400 doesn't match up with either a metric or imperial system size socket!!
.395 however does match up rather closely to 10mm which is .3937
2004 Limited V8
Old 03-22-2024, 07:35 AM #3
Yes, looking into that. Every 6 point I have is .400”. It also doesn’t help they put a .020” chamfer on the opening!
Old 03-22-2024, 08:10 AM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just go get some 6mm -1.0 thread capscrews, that's the thread size. I replaced all mine with stainless with a stainless washer couple years ago.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-22-2024, 09:30 AM #5
I just ordered a Ko-Ken Z-series 10mm socket. The claim much tighter tolerance than ISO/DIN spec and the chamfer on the face is less.
1/4 Sq. Dr. Socket 10mm 6 point Length 15mm Z-series– Ko-ken USA
Old 03-24-2024, 08:42 AM #6
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Here you go 90080-11590
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 06:08 PM #7
Great! That’s what I got. The dealership was confused even since the v6 and v8 use different bolts. Fingers crossed I get these stupid bolts out.
Old 03-30-2024, 10:12 PM #8
Got this done. The Koken Z series sockets are several thousandths tighter than a standard socket. They have a flank drive like shape to them. They worked well and are an incredible value. Also found a 10mm Snap-On Flank Drive Xtra (FDX). These are crazy expensive, super tight (tighter than std flank drive) and need a slight tap but they really , really grab. You may need pliers to pull the bolts out with these sometimes.
Dealership wanted $450 to do just plugs. I did plugs, coils and bolts for about $500.
Bolts: 90080-11590
Plugs: Denso 3297
Coils: Denso 673-1303
bolt , bolts , fit , ignition , measure
Discolored ignition coil revvhappy 4th Gen T4Rs 5 10-09-2015 11:02 PM
ignition coil problem sparky275 4th Gen T4Rs 2 11-26-2014 01:25 AM
2nd ignition coil gone bad in three months ... scrooster 4th Gen T4Rs 7 04-21-2013 01:25 AM
FS: Ignition Coil Pack Third Gen paperthin Classifieds - buy & sell (no commercial ads please) 1 01-25-2010 05:11 PM
New Ignition Coil 84DevilRunner Classic T4Rs 1 06-04-2008 10:25 PM
