Old 03-24-2024, 06:11 PM #1
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Installed new 5100s, extra nut now and lots of grease...
Hey guys,
I installed new Bilstein 5100s at .85 and FJ cruiser springs on my front, basically replacing the exact same setup I already have. I also purchased KYB mounts kits as well to replace the shock hats. The nuts they provide are 15mm. My old ones were 14mm, and I have a fancy 14mm ratchet which helps me get the single one in the back, so I just reused those.
As I was cleaning up, I found an extra bolt, which looks like one of the 3 bolts on the hat that secure the shock assembly to the car. I had my toolbox out and tools all over the floor, but I have a really hard time believing I randomly had a 14mm nut on the floor, that looks exactly like one of the 6 I pulled off the old suspension. I verified like 12 times that each of my shock assemblies have all 3 nuts fastened. I've. gone over everything a couple times, and nothing looks out of place.
Any ideas on where else this could come from? Left is 15mm supplied by KYB, and right is 14mm supplied either by last KYB kit, or stock Toyota.
Other issue... Can CV axles sling grease and be fine? I had some grease build up on the boot on the tire side on one of my axles. There was also old dried grease on other components too, but I did a pretty thorough inspection of the boot and didn't see any tears. I'm ok paying to get it replaced, but don't want to if I don't need to.
Thanks guys
Installed new 5100s, extra nut now and lots of grease...-upload-pic-jpg
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 03-24-2024, 08:32 PM #2
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Not sure about the bolt, but I recently used some 3M rubber electrical tape to fix my CV boots. One was completely torn off and the rest have cracks.
It is holding super well. Just cleaned it all with lacquer thinner then spun a few payers of tape on.
$5 CV axle fix #automobile #repair #hack - YouTube
Sent from my moto g pure using Tapatalk
gaber6 is offline   Reply With QuoteReply With Quote
Old 03-24-2024, 09:33 PM #3
Syr4RinNC's Avatar
Syr4RinNC's Avatar
There is also the nut that holds the strut shock on the shock mount in the middle. So one in the middle and three around the shock mount through the frame
The biggest thing with the CV is how its performing. It can leak some grease, but as as long as you arent noting popping, clicking with turning youre still good. You can try to repair the best you can to prevent more grease from leaking out
Old 03-24-2024, 10:29 PM #4
simple's Avatar
simple's Avatar
Definitely not the middle one! That one is a little beefier
Old 04-09-2024, 10:59 AM #5
grumpy02 grumpy02 is offline
Real Name: Stan
grumpy02 is on a distinguished road
Real Name: Stan
That "old" grease could have come from anywhere. Inspect the boots carefully & if there are no tears, look for where the "new" grease is coming from. If you have tears in the boot(s) you need to fix them or eventually water/dirt/grit will ruin the joints. How soon depends on how much crap you drive in.
grumpy02 is offline   Reply With QuoteReply With Quote
14mm , boot , grease , kyb , shock
Smokers Kit / Extra 12V Outlet Installed CJ3Flyr Engines / Suspension / Wheels / Tires / Audio / Accessories 27 04-14-2021 03:50 PM
4 Season 3 person tent for sale - LOTS OF EXTRA'S - $550 - Carmel, IN Okki For Sale: Non-T4R Items 4 07-09-2018 04:05 PM
Lots of "slung" grease by boot connecting to wheel carrier jthoms1 5th gen T4Rs 8 06-22-2016 07:23 PM
lots of grease found on parts covered by tie rod boot. Where is it from? dwmckeehen 3rd gen T4Rs 3 08-20-2015 11:16 PM
Help! Lots of grease behind passenger side front wheel ski4runner 3rd gen T4Rs 5 01-20-2013 09:54 PM
