Decals on Rear Window Outside
Lone Ranger
I wanted to put a decal on the rear window of my 2004 Sport. Will the decal last or will the rubber flange scrape it off over time as I put the window up and down?
The decal is a fish, if that affects your answer. :biggrin2:
I dont have any problem with the stickers on the back window of my 4runner. Just be sure to use a credit card to make sure the sticker is down on the edges.
I had a magnaflow and currently have a T4R.org one on there and they both held up pretty well on the back glass.
i had a 3D browning buck decal on my rear window and that tore right off, switched to to a non 3D one and its lasting fairly well. i also have a DU logo decal and its starting to peel from going up and down and it has torn pretty badly, but i think that is because I put it on poorly
It works for some and not for others. I guess it is worth a try as I already have a decal on the rear driver side window. I also wonder whether the rear window defrogger ;): will accelerate it coming off.
Jeff, it was the one without legs. The one with legs got away. :cool::D
ive had 2 decaks fall off. they were the printed on clear type. I have never tried the die cut. But, i think it all depends on how often you use your window.
I had a Clemson "C" decal that kept wanting to peel off every time I used the rear window so I thought about how I was going to raise the flange above the decal. At the time I was packing boxes and it hit me to put a little bit of tape on the decal and cut off the unwanted tape off with a blade. And it worked perfectly.
