Well, you have two choices:
1. Hide the scratches with a filler type scratch remover
2. Polish them out with an abrasive type polish
I have no experience with #1, so can't offer a recommendation.
For polishes, you can get polishes designed for machine or hand use. I don't own a machine polisher, so all I've used are hand polishes. I have had good success with both Griot's "Fine Hand Polish" and 3M "Swirl Mark Remover". Both work well, and I never compounded the problem with either of these products (i.e. they didn't add scratches).
A general rule is that if you can catch the scratch with a fingernail, you won't be able to polish it out.
edit: I just noticed you said you used rubbing compound! Be careful with that stuff as it is very abrasive and can damage the clearcoat. I had a friend that did this (over time) and polished the clearcoat right off his Explorer. Note that this was about 10 years ago, so rubbing compound formulations might have changed since then.
=Steve=
2003 V-8 SR5 4x2 4Runner
2003 BMW 330i 6sp
1965 Mustang (in Bondo and pieces)
1998 Jayco Eagle10UD tent trailer
Surefire Aviator
I'm SteveM and I approve this post.
