Old 08-09-2010, 12:36 AM #1
TONEDOG513 TONEDOG513 is offline
TONEDOG513 is on a distinguished road
V8 Engine Problems
Hi,
4.7L 2UZ-FE
Engine rattles during hard acceleration. Sound like pistons or lifters maybe timing chain rattle (but I think I have belt not chain in the 2UZ-FE)
This has been since the motor was factory new.
I use premium (93) mobile or shell gas
Lately I have noticed, rattling under slow acceleration up small hills while the a/c is on, and alot of rattleing when the engine is hot, a/c is on and hard accelerate.
56k on the motor
plugs changed at 30k
any ideas
thx
tony
TONEDOG513 is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 12:37 AM #2
V8 Engine Issue
Hi,
I could really use some help/advice.
I have a 2007 Toyota 4runner Limited 4.7L V8 2UZ-FE
After sitting overnight, when I startup in the a.m. and put it into any gear while holding the brake i get a knocking.
The knocking is definately engine, sounds like lower engine, a lower frequency knock, not like tap or a rattle.
The severity changes depending on the teperature, worse during colder days.
I always let the the motor run for a few min, at least until the needle passes the "c" on the temp gauge before moving.
It lasts for a block or two, or about 2 stop signs, hearing it at each stop sign.
I use Mobil1 5-30, change every 3k no matter what.
I use premium gas (93) from moble or shell
What could this be?
Thanks for any responses,
TONEDOG
Old 08-09-2010, 02:02 PM #3
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
I am not sure what is going on with your engine, but it is not normal (IMHO).
I have the same V8 and it is quietest engine I have seen in any trucks…
Since you still under powertrain warranty (60K ; 5 years) I would go to dealer immediately.
2013 Silver Trail (with KDSS)-Toyo Open Country A/T III, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 02:28 PM #4
jwyshrek jwyshrek is offline
Registered User
jwyshrek is on a distinguished road
Registered User
Well, can't say for sure, but sounds like you've got a rod about to let go.
Warranty or not, get to repair shop ASAP...and drive it as little as possible.
jwyshrek is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 06:09 PM #5
ALLEGRO's Avatar
ALLEGRO ALLEGRO is offline
ALLEGRO is on a distinguished road
ALLEGRO's Avatar
I agree !
Might be worth a trip to have it diagnosed, better to fix it in the shape it is in right now compared to it "letting go" and paying for an entire short-block.
Good Luck
2007 Driftwood Pearl Limited
ALLEGRO is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 06:56 PM #6
rockwall's Avatar
rockwall rockwall is offline
rockwall is on a distinguished road
rockwall's Avatar
Check it out
Definitely go to a Toyota dealer immediately. I would not even go to a private shop. I have a V8 and I agree that it the smoothest, most quiet engine that you will ever find. I finally have some growl since installing a Magnaflow cat back system.
Don't let it go!
2003 4Runner Limited V8 4WD;Pacific Blue Metallic; Cornfed 3/2 Lift; Spidertrax Wheel Spacers;Magnaflow Cat-Back Exhaust; Nitto Terra Grapplers 265/70/17; aFe Pro-Dry S Air Filter; Philips 4300 Xtreme HID Low-Beams; PIAA 540 Plasma Ion Fogs; HIR Hi-Beams; HIR main fogs; Man-A-Fre Front Skid; Alpine Head Unit w/I-pod Interface; Alpine Type-R 10" Sub; Kenwood 1000W Amp; JBL 10 speaker system; Steelcraft Bull Bar; Go Rhino Hitch Step; PIAA Super Silicone Wipers; TRD Radiator and Oil Caps; Brembo brake pads & rotors; TRD Carbon Fiber and iForceV8 Emblems on Hatch; all LED interior, Running Board, Reverse and License Plate bulb replacements; Weather Tech mats and Cargo Liner; Blitz Hybrid Cabin A/C Filter
rockwall is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 08:35 PM #7
dk27 dk27 is offline
dk27 is on a distinguished road
Originally Posted by TONEDOG513 View Post
Hi,
4.7L 2UZ-FE
56k on the motor
any ideas
thx
tony
Is that to say it's not the original? Also, I thought the V8's were 100K mile plugs? Was it mis-firing at 30K or were some 30K mile plugs?
dk27 is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 09:25 PM #8
netwon netwon is offline
netwon is on a distinguished road
Well, to start off your engine has a timing belt not a timing change. The service interval for the belt is just over 80k miles. Why did you change your spark plugs at 30k? The spark plugs are rated for 122k miles. Did you use regular plugs? That could/would cause interesting things. The truck calls for iridium plugs and they are expense for 8. In Canada we can pay upwards for $14.00CAD a plug.
Just a couple of thoughts,
Netwon
netwon is offline   Reply With QuoteReply With Quote
Old 08-09-2010, 10:05 PM #9
WOW! thanks for all the replies... im impressed....
I try to answer everyones comments...
1st I'd like to preface this by telling you guys that I am the computer consultant for the dealership that I bought the truck from. So I get to hang out with the techs, as I service the computers that service our trucks while they are working on my truck. Over time I figured out who the best tech in the shop was and stuck to him like glue. I also have the owners ear as he loves asking me questions and will always look into anything for me with no appointment ect...
There is only one problem he and all the other techs say that all the stuff going on with the motor is normal. :/
I thought that if anyone, i'd be able to get someone over there to help me figure out whats going on with this motor, but in actuality I think its working against me, as its tough to be a d&*k and demand fixes.
The truck has been maintained by this dealer since mile 1, oil changes everytime I come to do computer work, with mobil 1.
newton - I thought it had a belt, but thats what it sounds like, similar to the 4.0 sohc timing tensioner issue that was so big a few years back with the ford explorers. I had the dealership change the plugs as i get them for free and figured every 30k would be a good thing. yes they were the iridum plugs.
dk27 - It is the original motor, I guess the wording can be interpreted differently.
jwyshrek - how can a mechanic test/check if a rod is gonna go?
Thanks again for all your help,
Tonedog
ps.. if anyone knows a really good motor shop in NY area, i'd be willing to pay for a diagnosis, so atleast I have something to bring to the dealer with.
Old 08-09-2010, 10:44 PM #10
Tonedog
Do you have any warranty left on the vehicle? With only 56K I would think you would. If you have a warranty I definitely wouldn't take it anywhere that wasn't a Toyota dealership and have an once of work done.
Old 08-09-2010, 11:58 PM #11
Registered User
Registered User
There are experience mechanics/tech out there than can tell by just the sound the engine makes...some have a knack for it.
But to make sure, the bottom end of your engine has to be opened up, rod caps removed and the bearings inspected...only real way to know for sure.
By the way, have you checked your oil level lately? Any lights on your cluster gauge lit up?
Again, there is no way of knowing just from a worded description...but from what you describe, it does not sound normal or in any way good.
Old 08-10-2010, 12:03 AM #12
T4Fun T4Fun is offline
Banned
T4Fun is on a distinguished road
Banned
Hi,
4.7L 2UZ-FE
56k on the motor
any ideas
thx
tony
just a question, but doesnt that engine require 87 octane? if so, why are you putting 93 octane in it? putting wrong octane could be the problem for that long
T4Fun is offline   Reply With QuoteReply With Quote
Old 08-10-2010, 01:11 AM #13
dk27 - yes I purchased the platinum to 100k warranty with the truck
jwyshrek - yikes that sounds like fun! There is something about factory sealed that make me hate wanting to have the lower end taken apart, but i will to solve this issue.
- no lights commin on, everything according to the electronics displays/warning systems is good.
- oil is perfect level, looks normal in color
T4F - I have always run 93 on all my trucks, Also with so much info out there on the benefits performance wise, even if only a little by running the better fuel, I figured I was good. I think it even says to run it in the glove box book, now you have me curious, im gonna go re-read that.
- god could you imagine if I put 87 in there, I prob get a ticket for noise pollution. I say that only because I figure it make it worse.
I really am gonna get this thing to the dealer. God, I don't look forward to dealing with the blah blah required to get someone to pickup a wrench, its exhausting.
but either way at least by talking with you guys I have a direction, I can say "hey open that bottom end"...
thanks for that.
Any ideas let me know.
Tonedog513
Old 08-10-2010, 12:26 PM #14
midnight runner midnight runner is offline
midnight runner is an unknown quantity at this point
The knocking you hear when the engine is cold is the piston slap. It's fairly common as many people have posted about it. One post said Toyota knows about it, and it doesn't hurt the motor.
Once the motor warms up, the seals expand, and the noise goes away.
On your rattling, you'll have to explain the noise in more detail.
If you are in tight with a dealer, how come you just don't ask them to diagnose the issues?
midnight runner is offline   Reply With QuoteReply With Quote
Old 08-10-2010, 01:00 PM #15
M1911 M1911 is offline
M1911 is on a distinguished road
I have piston slap, but only hear it on cold starts in the winter. It goes away after 30 seconds or so.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
M1911 is offline   Reply With QuoteReply With Quote
