10-29-2010, 02:29 PM
Disabling vehicle for storage and anti-theft protection
I will be out-of-town for 4-6 weeks. I would like to disable my vehicle so it cannot be started. I usually disconnect the negative battery terminal anyways. In my previous 2nd generation T4R, in the electric box inside the engine bay, I used to take out a large (I believe blue fuse) fuse which would totally dis-able the vehicle. It would crank but never start up.
Is there anything like this in our 4th Gen. T4R that I can safely take out and re-install it later when I am back?
Thanks
'07 4Runner SR5 V6 4WD
Nautical Blue Metallic,Cyclone Pre-Cleaner
ShrockWorks rock-sliders,BudBuild skid-plates
Yokohama Geolander A/T, Wet Okole seat covers
KurtFab Diff. Bracket,Yakima MegaWarrior Roof Basket
10-31-2010, 08:09 PM
I believe the EFI fuse (1 or 2; I can't recall) will disable the engine. I used to pull it on my 2nd and 3rd gen.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
11-02-2010, 10:08 AM
Super Moderator
Super Moderator
Thanks
Unless the thief has a way to program a key it won't start. Your T4R has a 'chipped' key.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
11-02-2010, 11:12 AM
I have always wondered how good these "passive immobilizers" are. Cars with them certainly get stolen, but I wonder if it is only the real pros that can do.
I do know one way cars get stolen is that thieves break in the house and steal the keys. I keep my spare keys in a safe. I also use a club on my steering wheel and keep the key for that seperate from the car key.
2003, Sport, V6, 4WD
Overland Warehouse/Radflo 2.0 suspension, SPC upper control arms
2016 Trail Edition w/KDSS
Icon Stage 2 suspension, BFG T/A KO2 285/70/17, C4Fab sliders
11-03-2010, 01:50 PM
Real Name: Chris
Real Name: Chris
I usually pull the battery terminals completely, removing the ECU fuse couldn't hurt either. If you're storing the truck for a deccent amount of time, put some Sta-Bil in there and run it through your fuel system for 5 mins. Keeps gas from going stale, and your car will fire up with no hessitation
11-03-2010, 05:28 PM
Trust me, you're not starting an engine without the immobilizer and key matching. I ran into this in a recent engine swap. It'll start and die right away. Won't work.
EFI fuse is more than enough to stop most theives. It's a LOT less obvious than the battery cable pulled (easy to fix that) and you don't have to reset radio stations
11-12-2010, 05:36 AM
Why not remove all the fuses??!!
11-12-2010, 09:50 AM
Banned
Banned
Or why not take one tire out and put on a jack. Better yet, take all the tires out and put it on blocks. Now no one would like to steal it.
