LED Turn Signals
I've replaces most of my incandescent bulbs with LED's and I also replaced my turn signals and I rea that they might hyperflash and they did. I was wondering is hyperflashing bad and if so why? And how can I fix it and how would that work.
you can also buy a new flasher from superbrightleds for $25 I think.
I don't believe it will hurt anything but it is annoying when they blink too fast.
If u want to take a pic of your flasher to verify compatibility i can hook u up. But be sure u check it before u think about ordering one....what yr is your truck? If u want resistors i can help u with that as well.
Resistor installation: quite simple one wire on one and the other on the other.
I would like to replace the rear turn signals to LEDs and was wondering where you purchased them? The size is 992 or 7440A correct?
I put LEDs in my turn signals last year. I replaced the flasher with one from superbrightleds, quick and easy fix.
