Originally Posted by brian2sun
A body lift will still allow you to run larger tires which will give you more ground clearance and it's a lot cheaper. If you want it to go anywhere, go susp. Look around toytec.com and get some ideas and prices.
i was curious what was the difference between the body lift and susp lift. i assume the susp lift is better
