Same Problem...
This problem screwed with me for over a year ..exact same thing however it was with my Celica...I finally figure it out when i built my engine..
The injectors!
They were not sealing against the head so I was running lean..It would vapor lock and die but first idle low and stumble.
Fix:New Injectors
Have not had the problem since..I had tried everything that was mentioned above and it all failed..this worked for me!
When I started checking I first went thought all that was said above plus checking for vacuum leaks and no bends in the fuel line.
I took my injectors out and one of the O rings was not there so make sure they all are there..This is what was causing it to not seal!!
Good Luck!
2002 Celica GT-- CF Hood, TRD Short Shifter, TRD Shift Knob, Darton Sleeves, .040 Overbore, Injen CAI, Megan Racing Header, Aftermarket Rods, Aftermarket Pistons, Tint, 17's, HID Halos...TO DO--Exhaust, Cams, ECU
1997 4Runner Limited--FJ Springs, BFG Mud Terrain KM2...More to Come Soon...
Reason: Crazy Patients....Not enough time to type! :)
