Originally Posted by pkang414
Hey Everyone,
I was wondering, does anyone else have an issue where you press the button to allow the air to circulate in our car? I turn it on, but for some reason, it turns off. Is that normal? Thanks in advance.
Are you expecting this to work when the fan control is set to off?
All this button does is change from the A/C taking in outside air or just recirculating the inside air with the A/C. If you want outside air to flow through the car set the fan switch to low and voila air will flow. If the temp is set you Max A/C you wont be able to deselect this or turn off the A/C. Every car I've ever had works like this.
