View Single Post
Old 04-15-2010, 08:51 AM
4ShoreRunner's Avatar
4ShoreRunner 4ShoreRunner is offline
4ShoreRunner is on a distinguished road
Originally Posted by 4Funnr View Post
RTFM!
There, you will find that it says, "When AC is turned to Max A.C., the inside recirculation button will automatically illuminate."
Whenever you turn the system off and then back on, it will recirculate again as long as the temperature knob is set to "Max A.C.". You can always make it take in outside air after turning it on Max AC by pushing the recirculate button, but it will come back on if the engine or AC is turned off.
For all other temperature settings, the default is recirc OFF and must be turned ON if so wanted.
Are you talking to the OP? If so....
RTF-POST! His question was not about max a/c. I understand what he is asking - when fan is off, and esp driving at highway speeds, a small amount of air still comes through the vents, which can be annoying when you are comfortable with the temperature inside the car. To stop this trace air from entering the cabin, you can press the recirculate button; HOWEVER, for some reason in the 5th gen 4runner, it will only stay on for about 10 min before it turns itself back off. I have noticed the same problem, and do not know of a fix, but will try the "hold for 3 sec" method
::2010 Trail Edition:: ICON Front Coilovers w/Remote Resi's and CDC - ICON Tubular UCAs, ICON Rear Ext-Travel Shocks w/Remote Resi's and CDC - MT Long Travel Springs and Lower Links, 285/70 Goodyear Duratracs, Bronze Countersteer Offroad Type X, CBI Rear Bumper w/Tire Carrier, Shrockworks Sliders and full skids, Pioneer Z120BT, Rockford Fosgate Speakers and Amps, aFe Intake, Aux Battery set up, Roofrack by drabbits, SoCalTrail Behind the Grill Light Bracket
4ShoreRunner is offline   Reply With QuoteReply With Quote
