Registered User
Registered User
4Runner vs Tacoma - Towing??
I see the 2010 4Runner is rated to tow 5,000 lbs while the Tacoma V6 is rated up to 6500 lbs. Does anyone have experience in towing the same load (maybe 3000 - 5000 lb range) with a late model Tacoma and with the 4 Runner?? If so, how would you compare them??
Since the 4Runner is comparable weight, larger V6, better brakes (discs on all four wheels), both have 5 speed autos, etc. what makes the Tacoma rating higher - is it rear suspension and transmission cooler??
