04-25-2019, 01:00 PM
#37951
Got skid plate in this week. The T was falling off and the double back tape was messed up so I just pulled them all off. Put new tape and painted them dark blue to be a close match to the Nautical Blue.
Taking a week off in May to do nothing but work on the Runner.
04-25-2019, 02:05 PM
#37952
Real Name: Doug
Real Name: Doug
Finished my dual battery setup a few months ago except for the simplest part which I slammed out this morning. I have it wired to the battery for now so it's always on but might switch that so it comes on when the ignition is on. For now it'll do.
Sent from my SM-N950U using Tapatalk
04-25-2019, 08:14 PM
#37953
Lasfit 7443 LED’s, easy install, no splicing or resistor needed.
Parking light mode:
Turn signals:
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
04-25-2019, 09:37 PM
#37954
Added some personal touches.
www.johntrottocreations.com
2016 SR5 - Eibach Pro Truck Lift, Freedom Offroad UCAs, 255/75/R17 BFG KO2, C4Fab Lo-Pro Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, SSO Roof Rack, Boss Strong Box.
04-25-2019, 11:36 PM
#37955
Real Name: Pak
Real Name: Pak
Originally Posted by CRFofiddyF
Info on kit please
Everything was pieces together. First using the shrockworks dual battery tray.
2015 Toyota 4Runner Trail Edition/KDSS, SCS Stealth BR6, C4 rear bumper ,Relentless front bumper ,RCI under armor, 4.88 gears, dual battery, iKamper rtt
04-25-2019, 11:37 PM
#37956
Real Name: Pak
Real Name: Pak
Originally Posted by tb-av
That looks really nice. Would like to know how you handled your terminations on the passenger side batt.
I've got a lot going on over there that is far less than elegant looking.
I’ll take more detailed photos
04-25-2019, 11:57 PM
#37957
Originally Posted by aelarson
Hopefully your pup doesn't steal your truck
Good Boy looks like he's about to go for a joyride...
2014 Trail Premium | White | KDSS | Moonroof | Sliding Cargo Tray | Bilstein/Wheeler 2.5" lift with airbags | Ironman Offroad UCAs | BFG K02 255/75R17 | Sprint Booster
Previous: 2019 TRD OffRoad Premium, 2006 SR5 V6 2WD
04-26-2019, 08:36 AM
#37958
Originally Posted by PAKM4N
Finished my dual battery system.
There is a lot going on under the hood.
04-26-2019, 10:40 AM
#37959
MetalTech Fortress Bumper (Stage 3)
- OPOR Fog lights
- OPOR 30" LED bar
- Smittybilt X20 10k Winch
- Swapped grill surround to Black
- TRD grill Mesh
- FJ40 Emblem
04-26-2019, 11:23 AM
#37960
last Sunday, but.....
not today, but Sunday.....
installed a TRP PRO suspension I got from another forum member onto my OR with KDSS.
I set both coils to the lowest perch, but also installed some 1" (1/2" spacer) cornfed just to level it out. Now all wheel wells are 36". Just what I was looking for. ANY taller and it wouldn't fit into my garage. Stock rear springs, no spacers.
Took a little less than 2 hours for the install doing it by myself. The KDSS sway bar wasn't the pain in the garbanzos as people said it was going to be.
Here is a before and after:
2021 TRD Off Road
2008 GX470 (sold!)
2018 TRD Off Road (sold!)
04-26-2019, 11:25 AM
#37961
So what is the distance from center of hub to bottom of fender lip (front and back)?
04-26-2019, 11:35 AM
#37962
21" front
22" rear
even on both sides, luckily I didn't get the "lean" some people with KDSS do.
2021 TRD Off Road
2008 GX470 (sold!)
04-26-2019, 04:04 PM
#37963
installed the toyota black fogs. Picture with all stock and one side installed
PT41342191
04-26-2019, 05:22 PM
#37964
Real Name: Chris
Real Name: Chris
21" front
22" rear
You got exactly 1" lift up front. Strange since the pro suspension should lift .75 without anything extra at all. Had you not used that top hat spacer, you would not have gained any lift at all. Stock is 22 in the back, 20 up front. What size tires are you running?
04-26-2019, 06:12 PM
#37965
My ground-to-wheelwell-fender lip went up almost 2". I didn't measure at the middle of the hub on the stock stuff before. I didn't know that is the standard place to measure from.
Stock size 265 KO2s.
Maybe because I used the lower perches on the shocks?
2021 TRD Off Road
2008 GX470 (sold!)
