Storage with 3rd Row
Michigander
Since the third row takes up all the middle under-floor cargo space, there is not much left. I wanted a place that I could stash a tow strap and other items not used too often but need to be securely stored.
My big concern is having heavy items flying around in case of an accident or roll-over. So anything with mass needs to be tightly strapped down or in a latched compartment.
Anyway, there are two compartments that toyota did not care to make useful for us. They are on the sides of the third row seats by the back tail gate. The floor plastic (with carpet covering) is independent of the hinged floor covering the seat bottom in the middle of the cargo area. To get the side floor covers off: Pull up on the side plastic starting at the front near the 3rd row seat belt. Pull on the outside and hinge up toward the center of the cargo area. You have to pull hard.
After you remove the plastic false-floor panel, start to cut with a dremel. Cut off the center support leg (tube), cut the stepped clip that fits under the tie-down anchor (don't cut the whole clip, just the step portion) trim down the front long piece of plastic, and trim off two of the punch clips (long thin clips). Leave the two clips that are on the outside edge of the panel.
I have left the cut edges rough in this picture.
b0dc48ff.jpg~original
Thread two flat pieces of ribbon or rope between the two panel pieces (through the center hole where the support leg used to be) out to the outer side of the panel.
Now you should be able to slide the flattened tabs under the center portion of the cargo area, keep the rope loops up so you can use them to lift the panel, and now push the panel down at the outside edge until the two outer clips snap closed.
Repeat on the other side.
You now have two hidden compartments for less-used stuff.
I am going to look through the bins at the hardware store and come up with latches for the outside edge instead of relying on the plastic clips.
Once you pull the panel, you can see there is a decent amount of space being wasted in the corners.
7e747dcd.jpg~original
86d81d0f.jpg~original
I cut the "stepped" portion of the middle left tab in this picture so the left side of the lid slides easily under the middle panel. I also cutout the female "tab" that would slide into the button near the tab.
ca306267.jpg~original
Finished product (with temporary ribbon)
2faaaaaf.jpg~original
^ Those 2 threads don't really speak to what OP is wanting.. I think :/
But I wanted to do something similar, a storage compartment that only goes as far as where the third row starts. This way I never have to take it out if i want to use the third row.
I've been imagining it in my head but never sat down and drew it out.
I would like to see what others are thinking about.
I would love to see the pics. I know exactly where you mean. I actually expected the panels to be hinged for access and was suprised Toyota didn't hinge them or make the removable.
That's right, the linked posts are great resources with pictures of the interior taken apart. I am talking about the bottom back corners, not over the wheel wells.
I did not want to have a raised box in the back, above the floor, because it would limit the use of the trunk area (I don't have the 3rd row seats up that often).
The other option I was looking at would be to gut the inside plastic of the right side built-in storage compartment. The factory access door could be used to access the space I made useful in my above description. The left side access door is already open inside where the jack is located. The right side has even more room because there is no metal support to anchor the jack like the left side.
As always, a picture is worth a thousand words. I am working on it.
Yep, seems like a no brainer to come from the factory with a hinge.
I had a double cab tacoma before the 4runner and behind the rear seat had great storage space with shelves and all, and under the seat was more latched storage bins.
I am having a hard time finding a place to put all my stuff that I had in the tacoma.
I'm pretty sure he's talking about this, right?
Pics from Kingpin's build thread...
OK, I just wasted 2 hours trying to upload pictures.
I hosted the pictures on flickr.
Then I used the picture icon in the post edit box to "insert image", I pasted the short URL from flickr into the dialog box and all I see in my post is a box with a question mark where the picture should be.
Anyone care to help me? Does flickr block the pictures from being remote linked?
:wtf:
Post the link to your flickr address and I'll help you out. Make sure the pics are marked public.
That is the same area. These pictures show removing the upper piece of plastic cover. I removed both and cut out the depression (what I called a leg) that is in these pictures.
If you pull up on the floor panel from the front, the whole unit (two pieces screwed together) will come out together. Once it is out, you could remove the two screws that hold the upper piece of plastic and have access to the small depression as shown in the pictures.
I wanted to get to the unused area below the plastic false-floor.
Surprised there's no aftermarket bin that just pops right in there like there are for the glove box and center console. I just came from a 2004 Durango was spoiled by the storage space behind the third row.
Here's my version. Removed the 2 pieces on both sides to access the opening. Traced out the shapes of the carpeted pieces onto 5/8" plywood. Wrapped in trunk liner I found at a hardware store. Colour doesn't match exactly though but it is not seen since I have the cargo liner. Fits like a glove. If I did it over again I would trim another 1/8" off around the wood shapes to accommadate the thickness of the liner.
EDIT - you need to remove the floor panel to access the pieces on both sides. See link for more details.
http://www.toyota-4runner.org/5th-g...cess-rear-panel-pocket-subwoofer-install.html
Love this, I have Rago Molle panels since I don't use my third row, but I definitely need more storage space and love this idea. Going to copy one or both of these in the spring, thanks for sharing!
FWIW there is a lot of space in the wheel well. Once you remove the panel with the cigarette lighter you can access the 4 screws to remove the wheel well pocket.
Here's what the panel with the cig lighter looks like. It just pops out.
I got bored the other day and decided to take off the driver side rear well pocket as well. You can reach the screws by reaching through the jack opening.
