Body Panel coming loose.
Beakerbox
Has anyone else had an issue with the rear fender body panel popping out a little bit - at the area from the tail light, where it wraps around to the rear wheel arch (below the petrol cap). There's no damage or sign it was bumped. There seem to be two plastic clips that should keep the panels flush at that corner - but the fender panel sticks out about 5 - 6 mm from the upper panel and water runs in underneath it. The water just runs to the ground so it's not getting inside the vehicle. I've tried but I can't get them to clip back together.
Has anyone else experienced anything like this? or any ideas on how these panels go together? Any thoughts would be much appreciated.
