01-30-2014, 01:45 PM
Jack panel fire extinguisher
Disclaimer: My general handiness skills need serious help.
You could say I could have done more homework for my first mod (if you can call it one), and you'd be right, but I'm only 50% disappointed so it could be much worse...
I thought it'd be rad to attach a fire extinguisher somewhere in the back. I saw that
@ joneseyyy
used some Quick Fist clamps, which achieved the look I was going for, so I ordered them. I attached them both to the jack panel, grinned at my work, clamped in the fire extinguisher, and then watched the panel slowly open because the extinguisher was too heavy for the small plastic tabs on the panel.
While it will generally stay in place, I definitely need some help figuring out how to somehow reinforce the tabs or add something like a basic latch that would keep the panel secure.
Thanks in advance for any suggestions!
Mike
"We cannot change the inevitable. The only thing we can do is play on the one string we have, and that is our attitude."
-Charles Swindoll
01-30-2014, 01:49 PM
Real Name: Dave
Real Name: Dave
Them Be Me Mods - 2011 Black Limited / Trail Mutt
01-30-2014, 02:23 PM
Ha! I have the same axe in the same place.
My extinguisher is mounted on the right side, on top of the wheel well, with a single quickfist clamp, like the ones you are using.
01-30-2014, 02:30 PM
Empty out the fire extinguisher before clamping it on to the door, it might save you some weight and prevent the door sag
Maybe you should just move it over to somewhere more secure like Jeremy said? Not sure how well a latch would hold on thin plastic like that...if you still want to keep it there, the best idea I can think of is perhaps seeing if you can fit on a hinge to the door to help hold up some of the weight?
Nice idea though!
01-30-2014, 02:31 PM
Nice! Separate note, that Fiskars axe is crazy sharp. I'm guessing you don't have the third row? Unfortunately the space above the rear wheel wells in mine is filled with third row armrests that come right up to the windows.
And touche
@ phillyd2
! Help me beat this thing they call gravity.
-Charles Swindoll
Okki's Build Thread
No issue with my location.
In your case, I'm not sure if you can do a lot without adding more holes in the door and the surrounding plastic.
Shop Blum 2-Pack 5-in x 4-1/2-in Brushed Nickel Concealed Self-Closing Cabinet Hinges at Lowes.com
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
01-30-2014, 02:33 PM
I would put some modeling clay or something similar "inside" the "v" of the tabs. This should effectively push the tabs outward for more grab. Start with a little bit and see what kind of effect that gives you. If you want more resistance then just add a little more. You basically need something to "push" the tabs outward so that it holds in the locking position.
And if it doesn't work, you can just remove all of the clay.
01-30-2014, 02:37 PM
Nice idea though!
Haha, thanks Eddie. Yeah, unfortunately there's not really much space elsewhere that I could find back there since the third row armrests come to the window. And it really looks like a great spot otherwise, so I'm hoping I can keep it there. Some sort of small hinge should do the trick just fine, since it's really not pulling it like crazy or super heavy. I just don't really know what websites might carry something like that. Any suggestions? I could always just go browse my local Home Depot first but wasn't sure if you guys might know of some good sites that sell random stuff like this.
-Charles Swindoll
01-30-2014, 02:47 PM
That's a great idea, going to try that first Duc! Thanks very much, appreciate it...
-Charles Swindoll
01-30-2014, 02:58 PM
Originally Posted by Okki
Thanks Okki. Does that have a third row? Looks like tons more space than I have.
-Charles Swindoll
01-30-2014, 03:03 PM
Real Name: Patrick
Real Name: Patrick
bad spot Bro...becomes a flying projectile in a crash situation..
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
01-30-2014, 03:08 PM
No third row in mine. Just the sliding floor.
Okki
01-30-2014, 03:39 PM
You can probably find it at your local hardware store, but if you are a bit more patience I think you'd more than likely find something suitable here: McMaster-Carr
Be warned, that place is addicting, I some how magically spent 50 bucks to mount a 100 dollar roof basket a few months ago there
01-30-2014, 04:16 PM
Thanks for the link, hatch heaven on there! Was leaning toward Duc's simple suggestion until the comment about it becoming a projectile in an accident, probably a valid concern even with slightly better tabs.
-Charles Swindoll
01-30-2014, 04:33 PM
Real Name: Jeff
Real Name: Jeff
If you are dead set on that spot, here's what I would do.
With the cover in place over the opening, drill a hole between the clips on the leading edge. Drill through both the cover, and the panel behind it. Remove the cover and place a nutsert in the hole left in the panel (still attached to the truck).
Pop the cover back in place and screw a thumbwheel through the hole in the cover and into the nutsert to secure it.
.....but that's just me
HERE FISHY FISHY FISHY!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Fire extinguisher
Mtssurf1 |
General Discussions |
6 |
12-12-2013 10:59 AM |
Fire extinguisher??
Presta24 |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
4 |
03-16-2011 09:39 AM |
Fire Extinguisher...
mikey's2010SR5 |
5th gen T4Rs |
8 |
09-23-2010 11:31 AM |
Fire Extinguisher
J.A. |
4th Gen T4Rs |
10 |
04-13-2008 11:48 AM |
Fire extinguisher
zig |
26 |
07-12-2006 12:47 AM |
