Thread Tools Rating: Thread Rating: 13 votes, 3.77 average. Display Modes
Old 04-16-2015, 06:10 PM #31
madmex madmex is offline
Real Name: Frank
madmex is on a distinguished road
Real Name: Frank
Is there an DIY for changing out front struts and rears for the 5th gens?
madmex is offline   Reply With QuoteReply With Quote
Old 05-08-2015, 05:04 AM #32
Friedom Friedom is offline
Friedom is on a distinguished road
Thanks for putting together this list. Might want to add Sonoran Steel to the list, their gen5 lift is pretty well researched and rated. I have yet to find it's limits on my 11 TE. It utilizes Toyota progressive front springs from a niche 4 door TRDOR Tundra setup and custom valves billstein 5100s.
Sonoran Steel Toyota 4 Runner Lift (2010+) - $1,270.00 : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
I drive a TruckUV
'11 T.E. KDSS SS 3/2" lift, cooper at/3s, sleekster sliders, baja racks utility rack & ladder, new piece of bumper plastic
Friedom is offline   Reply With QuoteReply With Quote
Old 05-21-2015, 01:34 AM #33
AudiTech AudiTech is offline
AudiTech is on a distinguished road
Originally Posted by AudiTech View Post
Does anyone make a lift using just spacers that is like 1.5" front and rear?
I see Dynastar used to, I'm not find anything that small anymore though
Still hoping someone has an answer. I haven't found anything.
AudiTech is offline   Reply With QuoteReply With Quote
Old 05-21-2015, 11:01 AM #34
Neauxla Neauxla is offline
Neauxla is on a distinguished road
Pretty sure both toytec and daystar sells kits
2013 LTD 4x4 Magnetic Gray; Weathertech liners, Airlift1000, Camelback Metal Gear roof rack, Interior LEDs, trail rocker panels, Shrockworks step sliders, TRD Pro wheels, Cooper Discoverer AT3s 255/75R17
Neauxla is offline   Reply With QuoteReply With Quote
Old 05-21-2015, 12:07 PM #35
Cobalt Anubis's Avatar
Cobalt Anubis Cobalt Anubis is offline
Cobalt Anubis is on a distinguished road
Good Thread.
So let it be written, so let it be done.
2016 Toyota 4Runner SR5
Cobalt Anubis is offline   Reply With QuoteReply With Quote
Old 05-21-2015, 12:47 PM #36
cjacob316's Avatar
cjacob316 cjacob316 is offline
cjacob316 is on a distinguished road
cjacob316's Avatar
Just looked at wheelers, they sell a daystar 1.25" front spacer in both a preload and top spacer, you stack them to get the 2.5" lift. If that isn't enough, ome makes a 10mm spacer you can stack onto it, it will be a little more than 1.5" though.
2015 Magetic Grey Trail Edition w/ KDSS
Front: Toytec/Bilstein 5100 adjustable coilovers at 2.5". Rear: Bilstein 5100 with OME 895E rear coils.
ARB CKMA12 air compressor.
cjacob316 is offline   Reply With QuoteReply With Quote
Old 05-21-2015, 07:07 PM #37
Hawaiian4runner Hawaiian4runner is offline
Hawaiian4runner is on a distinguished road
Try cornfedsuspension.com
They custom make spacers if they don't already make the one you want. Pricey for a spacer but at least it's available.
Hawaiian4runner is offline   Reply With QuoteReply With Quote
Old 05-22-2015, 11:05 AM #38
It's wierd that no one else seems to be selling that same think. Daystar doesn't even list that on their site
Old 05-22-2015, 11:06 AM #39
Good info, I had never of them before. I emailed last night looking for more info about there 2" front 1" rear kit.
Old 07-01-2015, 02:52 PM #40
kapp_badbloodz kapp_badbloodz is offline
kapp_badbloodz is on a distinguished road
Thanks for making the thread
Can anyone confirm that the Toytec BOSS kit comes preloaded from factory? It says ready to bolt on but in my experiences I've installed coils and had to unbolt everything to establish proper preload. Never again. I'm vary weary to just bolt it up :S
kapp_badbloodz is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 03:01 PM #41
cjacob316's Avatar
cjacob316's Avatar
The front coilovers come fully assembled and the shock is threaded to that you can crank up the lift without having to compress the string. I'm not sure what else you're asking.
Old 07-01-2015, 04:04 PM #42
The spring that surrounds the strut sits in a channel that retains the spring with the top hat of the coilover. When assembled properly there has to be a certain amount of preload (or tension between the spring and top hat) to account for the weight of the vehicle + passenger/gear.
When I installed coils on another vehicle with advertised "set from factory" preloaded coils; there was no preload at all. They torqued the top hat down to restrict movement but not to vehicle weight specs. One bump in the road and FWAP FWAP FWAP goes my suspension. It sucked.
These are assembled from the factory. I am asking if the factory preloads the springs with tension to account for the weight of the vehicle. IE are they truly unbox and install or do I need to compress the springs and adjust for proper preload? I apologize if my lingo is off I come from different roots when it comes to suspension products.
Old 07-01-2015, 04:14 PM #43
WTERUNNER WTERUNNER is offline
WTERUNNER is on a distinguished road
Is the TRD PRO suspension considered a Lift? I have one on order and should be here in a week.
WTERUNNER is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 04:40 PM #44
cjacob316's Avatar
cjacob316's Avatar
You're over thinking it. As long as the top hat it attached, all you have to do is adjust the collar for lift. The top nut torque is done before you install the coilover onto the vehicle, you can check that if you want. I likely would, but it's only 18 ft lbs.
Old 07-01-2015, 07:31 PM #45
kaatahdin kaatahdin is offline
kaatahdin is on a distinguished road
The factory installed version is 1.5" (front only), no lift in the back just better shocks. I assume that's what you would get with the kit as well. Guess it would really be more of a level kit / suspension upgrade
Retired: RAM2500, ZR2, Ridgeline, Tundra, Titan, 5thGen, 4thGen, Titian, Xterra
Current: 2021 SR5 with TRD rims, (nothing else for now )
Next: 2024 Landcruiser (Give the 4runner to my teen)?
kaatahdin is offline   Reply With QuoteReply With Quote
4th Gen Buyers Guide KraTToR 4th Gen T4Rs 18 01-27-2021 10:57 PM
4th Gen Buyers Guide and Advice robbymartin 4th Gen T4Rs 1 11-04-2013 09:29 PM
4th gen buyers guide? sal6430 4th Gen T4Rs 3 04-05-2012 09:43 AM
4Runner buyers guide Turbo224 General Discussions 6 01-13-2011 12:50 PM
Buyers Guide Swancoat 4th Gen T4Rs 2 05-14-2007 10:40 AM
