Running boards 4th Gen to 5th Gen
Probably not, the body is significantly different than the 4th gen, while the frame is roughly the same; the running boards mount to the body.
Found a set on local CL, hoping they would fit. Surfing net for info but no luck. I might give it a shot; worse that can happen is it won't work
They look like this
Confirmed today that the OE running board mounting points are exactly the same design and spaced exactly the same between 4th and 5th Gens.
I installed Go Rhino 67427T oval side steps from a 5th Gen onto a 4th Gen (technically a 120 series GX470, but same difference). They fit perfectly. The steps sit fairly high on my truck, but I think these particular steps are designed to be that way even on the 5th gen.
I’m thoroughly shocked they fit. Thanks for sharing! This opens up more options.
They look like this
This post is old but this ever work out for you? I plan on taking the running boards off my 2009 (4th gen) before I trade it in and install it on the 2020 (5th gen) I just bought.
They're the exact same ones you have pictured.
Running boards transfer question
Did this work for you? I have a 2005 (4th generation) and would like to transfer the running boards to a 2020 (5th generation). I'm particularly interested in whether the light accents on the 4th generation running boards work when hooked up on a 5th generation. Thanks for any input you might have.
No, it didn't work. The holes lines up but the boards were too long and we're hitting the black fender piece...no idea what it's actually called.
They seemed to be, yes. But because the old running boards were hitting the front wheel fender I could actually get them to touch the bottom of the 4 runner. I could just eye it and it seemed if the fender wasn't in the way, the holes would have lined up.
alexaturner
