Old 01-19-2016, 01:18 PM #46
smkymntn's Avatar
smkymntn smkymntn is offline
smkymntn is on a distinguished road
smkymntn's Avatar
I searched and I found. I smelled the hot rubber smell recently after switching to magnaflow 12586 and doing my low beam HID- I actually thought it was the HID. I found my answer...that there is no answer.
smkymntn is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 12:53 PM #47
TOY2G TOY2G is offline
Real Name: Nathan
TOY2G will become famous soon enough
Real Name: Nathan
Funny thing is.....my wife's new GX does it also, but it has a rubber busing on the exhaust next to the spare tire, that I suspect is the culprit.
TOY2G is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:57 PM #48
bloodninja bloodninja is offline
bloodninja is on a distinguished road
Could be the combination of the new muffler coating and welding burning off
bloodninja is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 03:27 PM #49
Saker's Avatar
Saker Saker is offline
Saker's Avatar
It's not coming from any coating on the muffler.
I have over 36000mi on mine and a few weeks ago will fueling up on a trip, I smelled it.
Haven't smelled it since.
Nothing rubbing anywhere....
Best Regards,
Saker
Old 02-01-2016, 03:40 PM #50
Is it possible the drum brakes are sticking a little?
Old 02-01-2016, 07:11 PM #51
Saker's Avatar
Saker's Avatar
I doubt it. I've smelled it several times sice my T4R was purchased new....
always the right rear.
Best Regards,
Saker
Old 02-01-2016, 07:45 PM #52
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Arrow
Funny you mentioned "always the right rear".
I have 212 miles on my 16', as I passed the rear of the truck, on the right/passenger side, I smelled that burning smell. I thought it may have been the brakes being that its new. I will bring it up to the dealer when it goes it for its first oil change. Gald I got fire coverage.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 07:52 PM #53
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
The 4th Gen has the same burning rubber smell as well. At 160k mi, I have no issues. Never did find out where the smell was coming from. I did hear/read some where that the drive line would spin out some grease and hit the muffler and cause the burning rubber smell.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 10:38 AM #54
smkymntn's Avatar
smkymntn's Avatar
Interestingly and probably unrelated but since I put the Sprint Booster on I have not smelled it.
Old 02-02-2016, 10:42 AM #55
AP19Delta AP19Delta is offline
AP19Delta is on a distinguished road
Yea I also smell it with my 2016 T4R TRDP w/600miles. No idea what it is. Think its just the new car smell that burning off.
AP19Delta is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 10:57 AM #56
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
After 70k on mine, I still get the smell if I am driving it hard then park it in my garage. Its not a new car smell burning off.
Easy enough to reproduce on almost every 4 runner, before you get home, take your 4 runner on a long road and punch it from a stop to around 70mph. Don't let off the gas til you get there. Do this twice and then pull directly into your garage, close the door then smell at the right fenderwell.
I have two stop signs near my home, these are country roads with 4-way stops and nobody around most of the time. I've done this several times and tried the following:
turn off traction control, still has the smell
Slow down without using brakes hard, very light, downshift to slow, still has the smell
That rules out brake use for this smell. The only thing that I can tell is that it is definitely coming from the fenderwell area, which is also where the exhaust is. It is NOT coming from inside the exhaust, as the smell is not present at the tailpipe at all. It has to be the exhaust heating up and slightly burning one of the exhaust hanger rubber donuts near the exhaust.
Several folks have replaced their exhaust mufflers but still have the smell, so its not the actual muffler, and the only other thing that it could possibly be, aside from the isolator donuts, would be the heat shields, maybe they have some rubber undercoating, or use rubber grommets, or it has some sort of rubber sheet between it and the body? It is definitely a rubber smell, not a metallic heat smell.
One other thing I would check is the spare tire, only because its under there and its rubber. Maybe one day I'll drop the tire and do my little speed test to see if the smell goes away.
Of course, if anyone here has their spare tire off already, and can produce the smell easily, report back to see if that makes it disappear!
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 11:41 AM #57
mcarey86 mcarey86 is offline
Real Name: Matt
mcarey86 is on a distinguished road
Real Name: Matt
I have it.
I think it's coming from the driver side front fender area. Could be passenger side, but I've never ran over to check. It's definitely the front end for me though. When you guys are saying "the right side" is that passenger or driver?
Mine started around 4500 miles. Have about 5500 now and it's come and go.
Took it to the shop at the 5K mark and made mention of it. They looked around, said they couldn't see anything. Even let me get under too. As long as it's noted that I brought it in, I feel like I did my part.
Outside of that, I think it's just the character.
2015 Super White TEP w/ KDSS
275/70 KO2s | RCI Sliders | 32" OPT7 C2 LED Light Bar
XenonDepot/Phillips 4300k HIDs | Amber BD Squadron-Rs
mcarey86 is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 02:19 PM #58
4REIGN3R's Avatar
4REIGN3R 4REIGN3R is offline
4REIGN3R is on a distinguished road
4REIGN3R's Avatar
@mcarey86 right side meaning passenger side.
4REIGN3R is offline   Reply With QuoteReply With Quote
Old 02-02-2016, 02:26 PM #59
Real Name: Matt
Real Name: Matt
That's kinda what I thought.
Well, I guess I'm special. I believe mine is the driver side.
Old 03-04-2016, 01:12 AM #60
airjordan airjordan is offline
airjordan is on a distinguished road
I have noticed this as well with my 2016 TEP, front driver side and smells like a hot/burning rubber...you are not alone lol maybe its the direction the wind is blowing haha
airjordan is offline   Reply With QuoteReply With Quote
Burning rubber smell 4everunner 5th gen T4Rs 34 10-15-2019 09:58 AM
Burning rubber smell? Axewhlder 3rd gen T4Rs 14 12-16-2017 12:37 PM
Burning rubber/plastic smell Qyota 3rd gen T4Rs 16 01-13-2014 02:07 PM
Burning rubber smell after 'hot brake' smell westwind77 5th gen T4Rs 7 02-11-2013 01:26 PM
Burning grease / Burning rubber smell? Cape 4RUNNER 4th Gen T4Rs 3 01-04-2010 12:39 AM
