Old 04-11-2018, 12:13 PM #31
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
Originally Posted by vjack View Post
I am circling on a new Limited for my next vehicle... has anyone who bought the automatic running boards regretted it?
I think I do need running boards of some kind since I'm not tall (5'-8") and getting stuff up onto the roof is going to be quite a challenge without them. But I don't really like the look of the fixed boards. I just can't decide if the automatic ones are worth ~$1500.
you wont need running boards at 5'8"
tm965 is offline   Reply With QuoteReply With Quote
Old 06-23-2018, 07:44 PM #32
Frustrated Redneck Frustrated Redneck is offline
Frustrated Redneck is on a distinguished road
Smile 2014 Toyota Limited 4 Runner Automatic Running Board Issues
We are the original owners of a 2014 Toyota Limited 4 Runner 4WD which is equipped with automatic running boards. One year after having the 4 Runner we noticed intermittently the driver’s side running board would either not deploy when the door was open or not retract when the door was closed. The problem began to affect the passenger side running board as well. We brought it up during the routine service appointments at our local Toyota dealership.
I have been a mechanic for over 30 years and am well aware of the phenomena that everything works on the vehicle when the mechanic looks at the vehicle. Of course, the Toyota dealership could not find anything wrong. This continued for almost 3 years until 2018 when I turned in our 4 Runner for service and opened the driver’s door and the running board did not deploy. The dealership tested troubleshot the entire running board electrical system and found an open circuit in the Auto Step Controller Computer assembly (part #: 89720-35011; $339.90). Apparently, this Auto Step Controller Computer assembly has been used on 2012-2017 4 Runners. Beware and watch for the signs of failure listed throughout this post.
We have only had our 4 Runner back for a few hours but the running boards seem to be working fine. I made sure our Toyota dealership was aware that we had reported the automatic running board issues while still under factory warranty & any repairs should be covered. Toyota covered all repairs for the replacement of the Auto Step Computer Controller assembly.
The part comes with a 1 year warranty on parts & labor. I will be watching the running boards to make sure they do not start exhibiting the same failure characteristics as before.
I hope this helps somebody else with their Toyota 4 Runner automatic running board issues.
Frustrated Redneck is offline   Reply With QuoteReply With Quote
Old 10-18-2018, 10:37 PM #33
rfuller1 rfuller1 is offline
rfuller1 is on a distinguished road
Yes, I regret the auto-running boards. The fear that everyone has, they are beginning to be very inconsistent. It took about 5 years and 70k miles.
rfuller1 is offline   Reply With QuoteReply With Quote
Old 10-18-2018, 10:41 PM #34
Are they still working, out of waranty and hesitant to take it in for repair.
Old 03-16-2019, 05:02 PM #35
babygotfront babygotfront is offline
Real Name: TJ Francen
babygotfront is on a distinguished road
its the ECU not the motors
just had this issue on my 5th GEN 2016 T4R LTD ... auto-running board problem ... first the driver-side started acting up ... it would extend no problem, but wouldn't retract until i hit 5mph or so ... several months later, the passengers side starting exhibiting the same problem ...
took it to my dealer here in colorado ... nearly broadway/littleton blvd ... at first they wanted to replace both motors (first, they were both working - kindof, 2nd, odd that they both go out at/near the same time) ... anyway, they got the motors in (under warranty), replaced them ... same problem ...
their tech got on the horn with toyota's tech ... turns out to be defective ECU (controlling the running boards) ... motors were fine (which makes more sense) ...
they put the ECU's on order ... i'll update more after the parts arrive ...
btw, both motors if replaced after warranty ... $1602 per side ...
babygotfront is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 12:23 PM #36
Infinus Infinus is offline
Infinus is on a distinguished road
Yes there is a TSB for this issue. You can replace the controller yourself pretty easily and it can be found online for 225+shipping and is very easy to do yourself. I just did it this weekend after much frustration with my running boards.
Computer Assembly Side - Toyota (89720-35011) | Toyota Parts
Infinus is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 09:42 PM #37
T4RLMTD T4RLMTD is offline
T4RLMTD is on a distinguished road
Has anyone been successful in removing them and just putting in a fixed option? Is this difficult to do?
T4RLMTD is offline   Reply With QuoteReply With Quote
Old 03-28-2019, 12:59 PM #38
Traenk Traenk is offline
Traenk is on a distinguished road
I have had intermittent issues with our automatic running boards not retracting. If i were to push on the boards with my foot, then close the door, they would work so it seemed like resistance was causing the safety feature to engage and the won't retract. Once i started driving, they would retract.
I removed the running boards from the moving support (4 allen bolts on each board) and left the brackets attached to the truck and lubricated everything that moves. Things were not moving freely before lubricating.
When i reassembled, i did not tighten the boards completely down until they were in the retracted position. I had issues with it not working when i tightened things down in the open position. Please be sure to turn off the boards before going under the truck with the boards retracted.
So for me, seems to be a lubrication issue.
I did buy a new running board control unit thinking that was the issue but have not installed. The boards have been working without issue for 3 months now.
Best of luck to all with issues!
Traenk is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 09:18 AM #39
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
You can get fixed running boards, the old ones just un bolt. The only issue is the rocker panels. Get ones that are compatible with limited or modify rockers. There are threads here with resolutions.
I'll give you $100 for that new ECU
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 04-01-2019, 12:49 PM #40
Originally Posted by mbhjet View Post
My wife and I Purchased 2018 4Runner Limited with automatic running boards. Immediately noticed random behavior of the running boards retracting and deploying. Brought into dealer and could not "recreate" the problem. So at this point this is a huge safety issue for us. Decided to remove the automatic running boards and install static, but dealer could not install the static ones because the automatic running boards are integrated in the side panel. At this point the only option was to have the dealer fix the automatic running boards. Found a T.S.B. for 2012-2017 4Runners to remove and replace the ECU. In the meantime we were still having issues with the running boards deploying and/or retracting when they wanted to. Dealer finally replaced ECU and we are still having issues with the running boards. Went to dealer to ask for a replacement vehicle and they refused after knowing that there was a safety issue with the running boards.
Does this happen with the car off? If the car is being started when the running board deploys or stores, this will cause it to fail to deploy or store, as the car starting is taking most of the available power. If storing fails once you start to drive the board will retract at 5mph as a safety feature. If you avoid starting the car right when someone opens a door or within 3 seconds of a door closing this may solve your issue. I don't think they make this clear to owners in the documentation and likely why the dealer can't recreate the issue.
Old 04-02-2019, 12:58 PM #41
mbhjet mbhjet is offline
mbhjet is on a distinguished road
Angry
No it does not happen with the car off?
mbhjet is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 01:32 PM #42
Then I'm willing to bet if you avoid starting the car when someone is opening a door or within 3 seconds of them getting out that you won't have the issue anymore.
Old 04-11-2019, 09:41 AM #43
just a follow up on my ECU replacement ... working perfectly after ECU (not motors) replacement. i suspect (with no evidence) the ECU's are failing because of where they are mounted (underneath the 4runner, near the running boards) ... perhaps they're exposed to weather/conditions where they don't hold up based on location?
Old 04-11-2019, 06:04 PM #44
The running board ECU is actually in the driver's side footwell behind the fusebox inside the car. It also has a pretty interesting coating over the chips inside the box that appear to make it somewhat waterproof. I didn't closely compare the two to see what the difference is in chips.
Old 04-14-2019, 08:20 AM #45
thank you ... i stand corrected
Automatic Running Boards. <<<< 5th gen T4Rs 55 09-11-2020 11:00 AM
Mud Guards on Automatic Running Boards jhawkict 5th gen T4Rs 7 12-07-2016 01:08 PM
Reverse Issue '90 Automatic mofosti Classic T4Rs 1 10-19-2012 09:31 PM
Weight limit on automatic running boards RcadeRT 5th gen T4Rs 4 06-20-2012 02:31 AM
WTT: Sport Running Boards/Tubes for SR5/Limited Running Boards thirstyturtle 4th Gen T4Rs 9 09-14-2011 06:38 AM
