04-04-2017, 10:50 AM
#107
Real Name: Mark the Common Sense Wizard
Originally Posted by Saker
April 26, 2016
AUX CIRCUIT MOD
Here is the mock-up of my AUX CIRCUIT. The Pelican 1020 Box idea didn't work out as envisioned. Not quite enough space, so I scrapped that idea.
I think this will be fine as is, not as waterproof as a busman though....
Second photo is the AUX CIRCUIT Close-up installed.
Third photo is the AUX CIRCUIT completely finished and operating as designed
Where did you get the Plexi?
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
04-04-2017, 01:59 PM
#109
Wow... I really need more coffee... Carry on.
04-12-2017, 03:31 PM
#110
Viair 88p
@ Saker
I saw in another thread that you had purchased a VIAIR 88P compressor and were planning to install it under the hood. A few posts later, you said it was a no-go. I just ordered a VIAIR 88P with hopes of installing it under the hood. Before I spend a million hours of my life trying to get it to work, I was wondering if you could comment as to why it doesn't work...
2022 SR5 Premium 4WD
04-12-2017, 06:13 PM
#111
Originally Posted by GearJunkie88
@ Saker
IIRC, after looking at the mounting, it would not have been feasible.
Would have better served mounting if another model was purchased....so it rides in a carry bag in the back....
Best Regards,
Saker
04-12-2017, 06:45 PM
#112
Real Name: CT
Real Name: CT
Question
Sept 26, 2016
Aluminum Oil Filter Cap
Toyota Part # 15620-31060
Is it a straight fitment for a 2016 ??
04-13-2017, 02:21 AM
#114
Real Name: CT
Real Name: CT
Question
Yes sir.
I trying to buy one from a dealer but he said it's not going to fit.... whats the part number again? I gave them the number you had but they it won't fit.
06-06-2017, 01:59 PM
#116
April 2, 2016
Installed Plug and Play Rear Camera Override Dongle
AOB Switch Location and Functioning
Where did you get this button? It's awesome. Just ordered the reverse camera mod.
2017 Toyota 4Runner SR5 Premium 4WD (Midnight Black Metallic) <--- My 2017 T4R Build
1999 Toyota 4RUnner SR5 (Black)
06-06-2017, 07:33 PM
#118
thanks, ordered mine. along with the camera mod.
09-20-2017, 08:51 PM
#120
April 2, 2016
Thanking
@ bjohnston115
again for this mod!
My install went off without any issues. Rear camera still works as normal.
Depress the AOB Rear camera switch when in any gear, camera comes on.
AOB Switch dims properly just as the other switches do.
Wiring diagram
Camera Override Dongle Installed
Indication of Override Working
Hi I got this too and the AoB switch as well. Havent installed it yet. I know where to put the overide in behind the nav system. But How do I wire this and make it work? Do you mind explaining to me? I know I have to connect to 12v and ground and option of dash light. but the accesory wire go right to the 2 wires on the camera harness? Do you just put the 2 together in one splice to connect to the aob switch wire?? Look forward to hear back from you, thanks!
2016 MG 4runner TRD Pro
