Old 05-06-2015, 08:37 AM #1
Wazioc Wazioc is offline
Wazioc is on a distinguished road
Exclamation HELP: Did my 4Runner come with a rear spacer?
Hey everyone. Longtime lurker here. Bought a 2011 TE from a Honda dealer. Took me a while to track down a used one and drove 7 hours to go get it. Once I got there, it noticed it already had 285's and sat slightly higher than I thought it would. Upon getting it home and doing some more research I found out it has the Bilstein 5100 leveling shocks (and I'm assuming stock springs).
The Destination A/Ts that came on it finally wore out so I just upgraded to 285/70/17 Nitto TG G2... now I have rubbing issues. I'm going on a road trip to Colorado (From Texas) in about 4 weeks so I gotta get this fixed fast.
Solution 1: Chop body mounts - possible but need to find some metal and borrow my neighbors welder. If I take it out on any trails while I'm in CO, not sure if that will be enough in itself.
Solution 2: Lift it - Hadn't had a chance to decide on a full lift, so for the time being I was planning to bump the adjustable fronts up to the 3rd setting (2.5" from my understanding?) and add in a rear spacer (1.5" I believe)
Now to the question: While looking under the vehicle and trying to read how to do the suspension upgrades without screwing up my KDSS, I noticed this. It appears to be a white plastic/nylon spacer at the top of the rear springs. Does it already have a rear spacer lift? If so, I can't seem to track down who sells white ones like this. I can only find black spacers. It doesn't quite look stock, but I'm not sure what to do from here. Seems silly to swap white spacers for black if they are going to be exactly the same. Or is this some sort of stock thing that's supposed to be there and the spacer fits under it?
Wazioc is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 08:40 AM #2
4Surfin 4Surfin is offline
Banned
4Surfin is on a distinguished road
Banned
yes, that is a cornfed 1" spacer
4Surfin is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 08:47 AM #3
Wow, that was easy.... Thanks so much for the speedy reply!
Guess I'm back to searching to see if anyone has done with 5100 on 3rd setting with a 1.5" rear spacer. May be worth just upgrading to new springs in the rear instead of going with a spacer but I don't feel like I've done enough research to know which kit to go with.
Old 05-06-2015, 08:51 AM #4
Banned
Banned
you will want to set your 5100s to the 1.75" (3rd setting) if you want to retain that spacer. Search for user CENTCOMPETE he has that setup on his 4runner as do a few others. If you are going to tow anything you'll want coils. SAW 1.5" coils and the front 5100s on the 4th notch (2.5") is a pretty popular configuration....
Old 05-06-2015, 08:54 AM #5
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
Yep. Cornfed spacer. Bump the fronts to 2.5" and get rear springs. I have the Icon 2" lift springs in the rear and they are great.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 12:36 PM #6
ToxPath ToxPath is offline
ToxPath is on a distinguished road
Is the rubbing only on the inside fender liner?
ToxPath is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 02:04 PM #7
Yes, at full lock on level ground it rubs on only the driver's side body mount/mud flap. Any compression and it will rub driver or passenger body mount/mud flap area. Fronts seam to clear well enough by just trimming the fender liner though I do worry about the bumper edge at certain angles in compression... guess I need a front bumper too haha.
Just looking to fix any drastic issues right now.
Old 05-06-2015, 02:28 PM #8
badhabits's Avatar
badhabits badhabits is offline
Real Name: Karl
badhabits is on a distinguished road
badhabits's Avatar
Real Name: Karl
@4Surfin
Not meaning to hijack. Instead of raising the front 5100s what would be a good replacement spring for the front to go along with the SAW 1.5s
2016 Barcelona Red Trail
Its 5:00 somewhere.
WARNING: T4R.ORG IS HAZARDOUS TO YOUR WEALTH
badhabits is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 02:34 PM #9
Banned
Banned
Originally Posted by badhabits View Post
@4Surfin
not sure I would go SAWs if I was swapping the front coils... I am partial to OME
Old 05-06-2015, 02:39 PM #10
badhabits's Avatar
Real Name: Karl
badhabits's Avatar
Real Name: Karl
@4Surfin
I hope the OP can use this.
What would the recommendation be for doing just a replacement with slightly longer and heaver springs What would you recommend. I have tried to peace this puzzle together and have not come up with a solution.
Its 5:00 somewhere.
Old 05-06-2015, 02:44 PM #11
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
OME rusts like crazy.
All the kits running around Colorado looked rough after a year or two.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 05-06-2015, 02:57 PM #12
Banned
Banned
I dont drive in salt so maybe that is true.... been good for me though
Old 05-06-2015, 04:16 PM #13
I've been browsing around quite a bit for a long term solution, but having trouble deciding as well. Was looking at the Radflo 2.5 kit or Icon Stage 2. Had OME on my 96 but think I went too stiff with them. Usually do heavy loaded long road trips but it was rough for daily driving.
question , spacer lift , suspension
WTB One 1.5" 4th gen 4runner rear spacer Ohcrymore For Sale: Suspension/Wheels/Tires 12 05-13-2015 12:31 AM
FJ Rear Spacer on 4Runner morphious 4th Gen T4Rs 0 06-18-2013 02:36 PM
FS: 3" toytec front spacer & 1.5 rear spacer Keemonrunnin For Sale: Suspension/Wheels/Tires 5 01-16-2012 01:30 PM
FS: Toytec 1/4" Front Top Plate Spacer and 10mm Rear Coil Spacer ryhi For Sale: Suspension/Wheels/Tires 7 10-24-2011 02:01 PM
1.5" rear spacer (4Runner vs FJ). progress4m Engines / Suspension / Wheels / Tires / Audio / Accessories 10 11-06-2010 11:27 AM
