team_gforce
After 2 attempts by 2 different shops, I still feel a little disappointed in my alignment specs. I feel as though I should be getting much better numbers but am by no means an expert in geometry and alignment. So here is the story:
Step 1: Install Toytec 2.5 Boss kit. Net lift in the front is about 2.5" as measured from the center of the wheel.
Step 2: Install 285/70/17 Toyo OC AT2's on factory Trail wheels.
Step 3: Alignment done by Nissan dealership. (I know, i know, but this was the only place i could find a full set of the exact tire I wanted. Sept/Oct is not the best time of year to shop for tires in Alaska).
Specs: Driver Passenger
Camber 0.2* 0.1*
Caster 1.5* 0.9*
Toe 0.05* 0.05*
Total Toe = 0.1* Steer Ahead = 0.00
Thinking I could do better, I purchased and installed the Camburg UCAs with the MOOG ball joints. Got it back from a respected local tire store this morning and this is how it sits now:
Before Specs: Driver Passenger
Camber 0.4* -0.2*
Caster 4.0* 1.8*
Toe 0.07* -0.16*
After Specs: Driver Passenger
Camber 0.4* -0.2*
Caster 1.2* 2.1*
Toe 0.06* 0.07*
The caster leaves me quite disappointed as I was told that Camburg would add 2 to 2.5 degrees additional caster. When I dropped off the Runner this morning I asked to make a note of setting to the maximum caster possible. The before specs are all in the green for the driver, but afterward the caster is very low and out of spec?!? This is supposed to be one of the better places in town and have to make an appointment at least a week out to get in. I left my spare tire with them to put on an appropriately sized tire, so I will have to go back at some point. I am justified in thinking that they could do a better job on the alignment. On the after specs everything expect the caster is within spec, seems like there is some adjustability left? Is there something else I'm missing on why it seems so hard to achieve a higher caster?
Camber 0.2* 0.1*
Caster 1.5* 0.9*
Toe 0.05* 0.05*
Camber 0.4* -0.2*
Caster 4.0* 1.8*
Toe 0.07* -0.16*
Camber 0.4* -0.2*
Caster 1.2* 2.1*
Toe 0.06* 0.07*
