Old 07-21-2018, 06:27 PM #1
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
Agent_Outside: Adventures in a 4Runner Limited
This is my thread about my 4Runner - modifications, maintenance, how-to’s, and most importantly - the adventures it takes my family and I on. Photography, skiing, hiking, biking, and camping are all hobbies of ours, this is going to be a VERY picture heavy thread. I’m only going to post pics from adventures that involved the 4Runner, but rarely will the 4Runner be the main focus, I love the vehicle but it’s the thrills and experiences in life that I’m after.
When it comes to my 4Runner “build” you’re not gonna see a bunch of cosmetic mods aimed at getting Instagram likes or pictures of everything you could possibly bolt to it bolted to it. My philosophy in modding is high quality, reliable, thought out mods that add utility and usability while saving some weight wherever feasible.
2011 Toyota 4Runner Limited
Exterior/Protection:
- Southern Style Off-Road full length roof rack
- C4 Fabrication Summit Hatch Ladder
- iKamper Skycamper 4X hardshell rooftop tent bedlined in Rocky Black
- RCI Metalworks aluminum engine, trans, t-case skids with crossmember brace
- RCI Metalworks 20° rock sliders
- Stock Limited rocker panels modified for RCI 20° sliders
- Curt recovery point hitch insert
- Bullet Proof Fabrications rear King rock protection shin guards
- Gray TRD Pro 17” wheels
- Nitto Ridge Grappler 255/80/17 E
- Full size matching 5th wheel and tire
- OEM mudflaps on all 4 corners
- OEM ‘14+ tail lights
- Phillips Vision LED reverse, rear plate, and puddle lights
Suspension:
- King OEM 2.5” front remote reservoir extended travel coilovers
- King OEM 2.5” rear remote reservoir extended travel custom length shocks
- JBA caster corrected upper control arms with Cerakote coated high articulation ball joints
- Icon 2” lift standard load rear springs
- OME 10mm trim pack spacer
- DuroBumps front and rear bump stops
Electrical Setup:
- X2 Power (Northstar rebranded for Batteries Plus) BCI Group 24F 76ah AGM dual purpose starter battery
- Arc Light LEDS voltage booster for AGM batteries
- C4 Fabrication passenger firewall battery tray
- Vmax Charge Tanks BCI Group 24 SLR85 85ah deep cycle accessory battery
- RedArc BCDC1225D 12volt 25amp dual input DC and Solar onboard charger
- BlueSea CB285-40 40 Amp Circuit Breaker (x2)
- BlueSea 7615 Low Voltage Disconnect
- Shrockworks Power Distribution Module tray
- Bussman 15305-5-2-4 RTMR Power Distribution Module
- BlueSea CB285-80 80 Amp Circuit Breaker
- BlueSea 100 amp common busbar (x2)
- Contura II switches and Blue Sea 1039 dual USB fast charger fitted to new OEM 2014+ dash cubby
- Custom plug and play wiring harness made with TXL spec wire, Metri-Pack 280 series, Delphi Weather Pack, Molex Mini fit Jr, and Anderson SB50 terminals, seals, and housings
- Baja Design Squadron Pro amber driving/combo pattern with foglight pocket kit
- Baja Designs S2 Pro amber wide cornering lights on Cali Raised low profile ditch light brackets
- Freedom Design 22” light bar with Rago Fabrications behind the grill mounting
- Aurora LED roof rack flush-mounted scene camping lights (2 per side)
- Roof Top Tent Electrical Box - controls rack camping lights, tent power outlets, red interior tent lights, and white interior tent lights
- Dometic CFX35W refrigerator
- Overland Solar BugOut 130 solar blanket
Powertrain:
- K&N drop in air filter
- Fujimoto oil drain valve
- ARB rear diff breather
Interior:
- Weather Tech floor liners for first and second row
- Canvas Back cargo area liner
- ARC Light LEDs Icarus eXtreme white/red dome, map, and hatch lights
- OEM cargo area retractable cover
- DFG Offroad FX35/40 fridge slide with custom mounting plate
Recovery/Emergency:
- Maxtrax MKII
- ARB Weekender Recovery Kit
- ARB E-Z Deflator
- Smittybuilt 5.65 CFM 12v portable air compressor
- Boulder Tools heavy duty tire repair kit
- Adventure Tool Company tool roll with tools
- Garmin InReach Mini
- Emergency kit: Life Straw, Light My Fire Swedish FireSteel, knife, hatchet, small shovel, Adventure Medical Kit Mountain Weekender, emergency blanket, tarp, stormproof matches, toilet paper, etc.
Miscellaneous:
- Trasharoo
- Nemo Roamer sleeping pads
- Nemo sleeping bags
- Jetboil Genesis Basecamp
- REI Flexlite Air camping chairs
- Adventure Tool Company Camp Kitchen
- Adventure Tool Company Shop Roll
- Upgraded rear hatch struts
- Blizzak DM-V1 snow tires on stock 20” wheels
- Thule T2 XTR 916 & 918 bike carriers
- Debadged “Limited” emblems
Previous/Removed mods:
- BF Goodrich All Terrain T/A K02 275/70/17 E
- Prinsu full length roof rack
- Precision LED interior/exterior lighting
- Philips Vision LED interior lighting
- Toytec 2” machined rear bump stop spacers
- Rewired factory foglight switch for independent operation (highbeams, lowbeams, and foglights can all be on at the same time)
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 07-21-2018, 06:28 PM #2
Where it all began:
I've always been a car guy. I've never liked trucks, never wanted a truck, never had any interest in a truck. In fact, after buying the 4Runner a bunch of my friends gave me crap about it because I always said trucks were for hillbillies. Living in the Midwest (Chicago) that was totally true, everything was flat, the worst you came across was a dirt road if you drove hours to get to it and you may have to park in a field during an event of some kind. but people bought trucks and lifted them and gave them the off road look for nothing. I never once even considered a truck living there even despite have an outdoors active lifestyle (hiking, biking, triathlons, skiing, ect.) That mindset changed when I moved to Colorado. I had a modified 4 door MK6 Volkswagen GTI and first time it was no longer practical. From dirt and gravel washboard roads and driving over cattle grates in route to trail heads for mountain biking, to driving a lowered front wheel drive car up mountain passes in the snow with 300 ft/lbs of torque to go skiing, it just wasn't practical for my lifestyle in a mountain environment.
This thing hated rough unpaved roads.
Fall through spring could be bike or ski season, this is all I could do to maximize space but it was always limited to 2 people plus gear.
Heading up to go skiing it was common to plow snow with the front while hoping the snow tires keep biting. It didn’t take much to really bury the car.
And stuff like this is no joke.
So, I started looking for a replacement. My first thought was a Subaru would be perfect. I was all for it, until I actually drove one. I really wanted to like them but it was bad. It felt like I was sitting on a folding chair with a cushion surrounded by an interior designed and built by Fisher Price. They just felt so cheap and crappy, I couldn't do it. I was working at a car dealership so I'd regularly take used cars home for a night to spend some time driving them and seeing what I liked and didn’t like. After literally a year of casual researching, looking at, and driving everything from small hatch backs to pick up trucks I had a pretty specific list of what I wanted in a replacement for my GTI.
This was my list of firm requirements:
- Real truck/SUV (body on frame, no crossovers)
- 4-wheel disc brakes with ABS
- 4 doors
- 2" hitch receiver
- A center differential inside a low range transfer case (full time 4WD that you don't have to mechanically lock any part of the drivetrain, I did not want 2WD or locked 4WD)
- I had to be able to adjust the driver’s seat to where I want to sit and then be able to get out and fit comfortably in the seat behind that one (I'm 6'2")
- It had to fit me laying down in the back with the seats folded flat for sleeping in it
- Reliability and long-term durability
- One touch auto up and down on ALL of the windows
- Split folding rear seats
- The ability to comfortably fit 4 adults with all of our ski equipment inside the vehicle.
On 8/27/14 after a long time the winner was a used 2011 Toyota 4Runner Limited – 4.0L V6, full time 4WD, automatic, silver exterior, black interior, smart key, heated full power leather seats, navigation, voice recognition, bluetooth phone and streaming audio, one touch up and down windows, dual zone climate control, 2" hitch, 5,000 lb tow rating, 4 and 7 pin trailer wiring, steering wheel controls, sunroof, homelink garage door buttons, 20" alloy wheels, 15 speaker JBL system, running boards, heated mirrors, roof rack cross bars, auto dimming rear view mirror, 6 disc changer, Aux jack, USB hookup, iPod hookup, backup camera, 4 wheel disc, front and rear 12v and 120v power outlets, XREAS sport suspension, side curtain airbags, knee airbags, front airbags, side airbags, etc. It had 29,000 miles, 1 owner car, clean carfax, all the maintenance records, and they even had the original $43,000+ window sticker. It was mechanically perfect but with a lot of minor cosmetic flaws up close. That was perfect for me, the price was lower, the value was better, and not being a mint perfect condition truck, I wouldn't be so stupidly over anal about it like I have been with every other vehicle I've owned.
New with the old
Old 07-21-2018, 06:29 PM #3
First thing was the bike racks
Much happier hauling bikes on dirt
Out on small 2 lane middle of nowhere cliff side mountain roads where there is zero ambient light other than what you get from the moon you can never have enough light. Sometimes those roads aren't quite 2 lanes or paved.
So, the first mod was finding a wiring diagram and figuring out what wires I needed to rewire the fog light to work independently of the high beams. Normally you can have low beams and fog lights or low beams and high beams. I wired in a relay to so anytime the ignition is on and the OEM fog light switch is turned on the lights work. Now I could run high beams, low beams, and fogs all at the same time. It’s a simple and practical, although technically illegal modification.
Pretty quickly I started taking it out into the mountains.
Old 07-21-2018, 06:30 PM #4
Fall colors faded to winter and ski season began. The Blizzak snow tires went on and I stated hunting powder days.
It became obvious the slush catcher steps needed to go in the garbage and some mud flaps would help.
That’s a bit better.
My wife and I hit the slopes, a lot.
Old 07-21-2018, 06:30 PM #5
Spring rolled around where conditions can vary considerably.
Taking a trip up to Rocky Mountain National Park
Mid 70’s shorts and t-shirt weather and you have to tun back on your hike because you didn’t bring snow shoes.
Wheels and tires came next
Hitting the trails with wifey
There’s still snow to be found
Old 07-21-2018, 06:31 PM #6
After banging my way through some stuff like this I decided it was time for skids
That’s about the same time I put together the Oh Shit Kit. I don’t think the pictures are quite up to date but the kit contains the following Tow strap, jumper cables, roll of blue shop paper towels, utility gloves, 12V air compressor, small first aid kit, Mountain series medical kit -weekender, 200 alcohol prep pads, Wound Seal powder, 2 Heatsheets emergency blankets, an adventure pack of hand, body, and toe warmers, Instafire all weather fire starter fuel source, storm proof matches a rain Poncho, 6x8 medium duty tarp, Rescue Tape, Gorilla Tape, Gerber folding hand saw, automotive fuses, razor utility knife, pocket knife, tire plug kit, needle nose pliers, side cutters, multi bit screwdriver, channel locks, standard and metric allen keys, 24" pry bar, 51 piece socket/ratchet set, hammer, ratchet straps, flashlight, 12v plug in search/spot light, bungees, garbage bags, and zip lock bags.
Easter at RMNP
Old 07-21-2018, 06:31 PM #7
4th of July, we drove up the Kenosha pass to where the Colorado Trail crosses it. From there we took the mountain bikes from Kenosha pass up over tree line to the Georgia pass before coming back down.
Tearing through the Aspens
The first preview of what’s to come
We worked our way up through national forest
The air was getting thin and so were the trees
It was well into the 90's at home in Boulder but we were playing in the snow in the high country
Above tree line
Old 07-21-2018, 06:32 PM #8
Next up was Mount Evans, the highest paved road in North America and because of some construction it was closed to cars.
We loaded up the bikes and took the truck to Echo Lake where we started our ride.
You could see treeline getting closer
My wife grinding away
Plenty of snow in July
Summit Lake
Still climbing
Still climing
Almost there
14,130 feet above sea level. It was f'n COLD, windy, and we got snowed on.
We were out of our element and into theirs
Old 07-21-2018, 06:32 PM #9
We took the truck to town of Como at the base of Boreas Pass. We rode the Gold Dust trail up to where it ends near the top of the Boreas pass, we took the pass up tot Continental Divide overlooking Breckenridge before descending back down.
That's the ski slope of Breckenridge
For the 4Runner’s first birthday we took it out to play
Old 07-21-2018, 06:33 PM #10
With fall coming I headed up to high country for a drive. The aspens had starting to change up there and the scenery is phenomenal. The trail was cool, it was narrow rugged off roading, I scratched the truck a little with some branches, banged up my skids a bit, banged up my mudflaps a lot, did a few small sections of rock crawling, a water crossing, even found a dead Ford. It was nice being out there where the cell phones don't work, I even got to see some old mining ruins.
At one point I came across some hikers, they said with the truck sitting on top of a mountain with nothing man made in view in any direction, their first thought was that they came across a 4Runner commercial lol
Old 07-21-2018, 06:33 PM #11
Minor damage, it happens.
Old 07-21-2018, 06:34 PM #12
Exploring mountain passes. I70 to Georgetown, Guanella Pass to Kenosha Pass to Boreas Pass to Breckenridge, Swan Mountain to Keystone, drove up the back side of North Peak at Keystone ski resort, then the Loveland Pass back to I70 and home.
On a ski slope at Keystone
Old 07-28-2018, 04:45 PM #13
I placed the following order from Rago Fabrication:
-Toyota Factory Square Switch with Bumper LED Bar emblem and text.
-2010-2013 5th Gen Toyota 4Runner Hidden Bumper Brackets.
-22" 5D Freedom LED Bar.
-Wiring harness.
-Relay Holder
I'd thought I'd share my thoughts and feedback on everything and show my process for a nice clean installation.
The buying process was quick and easy and they were very fast to confirm the order, ship it, and send tracking information. They were great to deal with. It arrived while I was out of town for work, I got home and only had a day until we had visitors arrive for the week. So all this stuff sat there staring me in the face while refusing to install itself for a quite a while until I finally made time and started on the install.
Summary: With all the hype surrounding Rago lately I had high expectations. I was really hoping for top quality at great prices but in reality, it’s a bit more on the side of you get what you pay for. Overall, I think they provide an acceptable product that is a reasonable value. The foundation is there but I feel they skimped out on some of the detail work. The bar and brackets are worth purchasing, it’s a pretty good buy when they offer a sale. The wiring harness is generic and made with a lot of cheap parts plus it requires a considerable amount of modification if you want anything that resembles a neat and clean installation. If you're electrically literate the harness is a waste of time and money, just make your own. If you don't have electrical experience this can be used as a bare minimum, sub-par, almost plug and play way to make the bar function. I’d give it some more credit if the connections were sealed from the elements since most of it lives in the engine bay. The relay holder is a complete and total waste of money as it doesn’t actually secure the relay. The integration between the bits and pieces that they sell together as a kit was a little lacking.
Everything unpacked and laid out.
I'm not getting into a step by step on how the bumper so we're going to jump to the bracket and the bar installed. The bar itself feels pretty solid and well built for the price point and the light output was reasonable.
The brackets were nicely made and the powder coating appeared to be high quality. There was a considerable amount of adjustment in every aspect of the fitment, which I personally am not a fan of, its vehicle specific, you shouldn't need to slide it all around to make them fit if it was designed correctly to begin with. This is the outer portion of the right side bracket installed.
Inner portion of the right side bracket installed. The additional brackets are a nice touch, without them if you give the bar a gentle tap (simulated off-road bump, pothole, whatever) the light would bounce and it took a couple seconds for the light to top vibrating and stabilize. With the second bracket its nice and solid.
This is the left side bracket (stabilizing bracket not installed at the time) and the start of how I did the wiring. I drilled a small hole in the air deflector and ran the wiring through it to keep it away from metal objects.
From there I fixed the wiring to the flap below the headlight, again to keep it away from metal and things that could chafe on the harness.
I wanted to be able to disassemble if need be so I didn't want to splice the LED bar harness straight to the wiring harness. I thought it was kind of cheap to have the light bar just come with stripped wire pigtails. Ordering the bar and the harness I fully expected a waterproof 2 pin connector to be able to just plug right in. I added waterproof connectors sealed to the wiring. I put a male and female on each side of the harness (as opposed to both the males on the bar and both the females on the harness for example) so even if you ignore the colors of the wiring it can't be hooked up backwards.
In the engine bay I used the harness brackets already there for factory wiring and routed it right alongside it.
The battery is loose and shifted over to gain some extra room to slide a hand down there to route the harness.
The harness runs back to the relay mounted to the Rago relay holder (more on that in a minute)
This is the extra length I cut out of the harness going to the light bar.
Now, for the relay holder. Junk! If you watch their install video https://www.youtube.com/watch?time_c...&v=smD1jX9eJpg you need to use a knife/pick/small object to release the relay from the mounting tab. The Rago relay holder has nothing to keep the relay in place. It slides on and off with no resistance. You’re buying an extra bracket to make it less secure. Not cool, that's quite the design oversite in my opinion. Plus, as you'll see in the next picture if you try to cleanly route the B+ wiring around the fuse box it will not reach the battery using their harness and their relay holder. Rago did offer to go against their return policy and let me send it back for a refund but at this point I already tossed out the tab that comes with the relay to actually mount it securely. I put a dab of black RTV on it before sliding the relay over it to keep it secured.
Rago-013vid
Old 07-28-2018, 04:46 PM #14
I temporarily got it hooked up to verify function.
Next, I modified the front plate a bit, I shape the front plate to match the contour of the bumper so it's not hanging down and blocking light output.
To get a good starting point with aiming the light I measured all 4 corners to the face of the lower grill and adjusted it all completely square and level.
Next up was the switch side wiring of the harness. I wanted to make as small of a hole as possible in the firewall grommet so I used one of my terminal tools and removed the connector, this way I can tape the wires up to a zip tie and pull a relatively small mass through the grommet.
Stagger the wires a bit to keep the bulk down.
Size comparison of the harness connector to my way.
I poked the corner of razor blade into the harness boot and stretched the hole out with the harness to keep a nice tight seal.
I ran this harness along the factory harness again to keep it clean looking.
with that stuff in the cabin I put the terminals back into the connector so nothing would touch and went back under the hood. I wanted to get the under hood stuff finished because I was running low on time. So working on the power and ground setup the power wire was absolutely going to have to be extended for a clean install if you're running their harness and relay holder together so I started messing around with that. First thing I noticed is how bad the fuse holder it. I pulled the terminal because I needed to extend the wiring and I’d rather have room to work. This is how bad the fitment to the actual blade of the fuse is. I'm going to cut this thing out and use a proper one that has better contact and is actually sealed up for use in exterior applications. But for now, it went in as is.
Rago-024vid
I extended the wiring using the excess that I cut out earlier and sealed it up.
The fuse holder is just kind of sitting there since again, I'm going to cut it out and use something more appropriate to the application and it doesn't really have a way to be mounted besides double sided tape.
I reused the shielding that I cut off the harness earlier for a little extra protection on the power wire and to help hide it and make it blend in. The power wire is zip tied to route along the negative cable heading towards the engine.
I pulled the wiring right up along the positive cable and bolted it to the terminal.
Old 07-28-2018, 04:47 PM #15
On the interior side of the harness (after removing power those wires). I ended up cutting off a large portion of the harness.
I shortened, connected, and sealed 3 of the 4 wires.
The 4th wire is the illumination wire, I was about out of time so I'll save that for another day. I wrapped it around the harness and tapped it up.
All hooked up ready to go.
The light bar logo still goes on and off with the light itself. Considering the interior backlighting is an orangish color I'm not a big fan of the blue.
255/80/17 , camp , king shocks , limited , rci metalworks
Project Hibagon ヒバゴン | 1998 Limited Bodhi 3rd gen T4Rs 12 09-06-2023 06:03 PM
Seattle_SR5's 99 Limited 4WD: Repairs, Upgrades, Adventures and Build Thread Seattle_SR5 3rd gen T4Rs 15 02-11-2020 04:54 PM
dustins '00 limited - build/photos/reviews/adventures xdustin 3rd gen T4Rs 21 08-08-2018 09:55 AM
Photoshop 4runner adventures Knight-Errant General Discussions 17 11-17-2015 12:21 AM
