Old 11-16-2015, 07:59 PM #1
raycie raycie is offline
raycie is on a distinguished road
Rigid SRQ2 Flood ideas
Looked through some of the pictures and threads.. Couldn't find many ideas.
I have a set of Rigid SRQ2s (Floods) that I had for my old truck. Now that the truck is gone and I have the Trail, wondering where I should install.
1. Had a set of camping/backup lights on my Tacoma. Not sure if there are any easy mounting locations on the 4R.
2. Have the extended Front Runner roof rack. I could place at the corners to use as ditch lights.
3. Looked at the CBI hood mounts but se that you need to trim/cut the plastic by the hood.
Any other ideas on where to place these...
raycie is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 08:52 PM #2
cjacob316's Avatar
cjacob316 cjacob316 is offline
cjacob316 is on a distinguished road
cjacob316's Avatar
What year?
2015 Magetic Grey Trail Edition w/ KDSS
Front: Toytec/Bilstein 5100 adjustable coilovers at 2.5". Rear: Bilstein 5100 with OME 895E rear coils.
ARB CKMA12 air compressor.
cjacob316 is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 09:17 PM #3
Originally Posted by cjacob316 View Post
What year?
16.. Sorry.. I should make a sig..
Not looking to cut stuff up quite as yet... a whole whopping 16 days old...
Was thinking of the rack, but that is a heck of a lot of wire to pull from the A-pillar to the rear and back up to the front... Clean, but a lot of wire... lol..
Was also thinking on the sides of the rack for camping lights, but maybe not for these floods.. maybe a diffused would be better...
Anyone else make hood (ditch) mounts that you don't have to do any trimming???
Old 11-16-2015, 09:49 PM #4
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
You don't really have to cut with the CBI brackets, I used a heat gun to warm it up then shut the hood. It took two times and made it fit fine, it's just slightly deformed for them to fit. Really pretty easy stuff and if you ever wanted to go back to stock I don't see any issue as it's a small amount of space you create. I would go that route honestly. (I am only using one as a cb antenna mount myself)
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 11-20-2015, 09:50 PM #5
cjacob316's Avatar
cjacob316's Avatar
You could also put them on either side of the grill badge if they fit there.
Old 11-21-2015, 12:42 AM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
1. Had a set of camping/backup lights on my Tacoma. Not sure if there are any easy mounting locations on the 4R.........
I installed mine here using existing bolts underneath:
Also, an idea here how to use existing trailer circuit to run your back up lights:
Warn Backup Lights - Trailer Power ?
Best Regards,
Saker
Old 11-21-2015, 02:34 AM #7
Hellamatic's Avatar
Hellamatic Hellamatic is offline
Hellamatic is on a distinguished road
Hellamatic's Avatar
16 days....I was cutting on mine within about 16 hours, haha
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
Hellamatic is offline   Reply With QuoteReply With Quote
Old 11-21-2015, 01:38 PM #8
I looked back there are wondered about those bolts. I May definitely use that as a backup solution. I had the SRQ backup lights on my Tacoma using some sock holes.
I may definitely need to pick up some SRQs diffused for that location, but SRQ2 fogs would be totally overkill for some backup/camping lights..
My Build------>http://www.toyota-4runner.org/5th-ge...ail-build.html
IG - @battadohana
Old 11-21-2015, 01:41 PM #9
That could be doable.. but gotta see if there is a solid attachment point??
IG - @battadohana
Old 11-21-2015, 01:42 PM #10
Good on you brother... bigger man than me.. but what we're you possibly cutting up the same day????
IG - @battadohana
Old 11-21-2015, 10:21 PM #11
Miguelon's Avatar
Miguelon Miguelon is offline
Real Name: Michael
Miguelon will become famous soon enough
Miguelon's Avatar
Real Name: Michael
I have mine mounted in the rear bumper
Rigid SRQ2 Flood ideas-tempfileforshare_2015-05-03-20-33-23-jpg
2014 UnLimited
Shrockworks Winch Bumper, 5% Window Tint, Spyder Trax Spacers, Ramsey 9500, Toytec 3" lift, 3rd Row Seating, Entune Navigation, Yakima Skybox Pro 21, 275/65/20 Dura Tracs, Amsteel Synthetic Winch Line, Beaver Step, BMC Mod, MagnaFlow 14", Interior LED, Camelbak Metal Gear Full Rack To be continued......
Miguelon is offline   Reply With QuoteReply With Quote
Old 11-21-2015, 11:02 PM #12
You cheat... you have a awesome rear bumper.. lol
IG - @battadohana
Old 11-21-2015, 11:36 PM #13
Hellamatic's Avatar
Hellamatic's Avatar
Fender liners. I did lift and tires before taking delivery.
Old 11-22-2015, 02:43 AM #14
Yea... I saw you bought it with a lift and tires..
IG - @battadohana
Old 11-23-2015, 09:23 AM #15
cjacob316's Avatar
cjacob316's Avatar
There is a metal cross brace right there.
Rigid Dually Spot vs Flood Testing TotalAutomotiveLV General Discussions 5 02-19-2015 03:09 PM
FS: Rigid Dually LED Flood lights $185 shipped RiDE For Sale: Non-T4R Items 1 11-22-2014 08:25 PM
Rigid Duallys Amber flood Icepuck72 For Sale: T4R Items 5 09-16-2014 08:30 AM
FS: pair of Rigid Amber Duallys, flood Icepuck72 For Sale: T4R Items 6 03-03-2014 09:02 PM
